I upgraded influxdb from version 1.5 to 2.7 by selecting the automatic option. The upgrade finished successfully. I start the service and lunched using localhost;8086. The upgraded databases is not list. I cannot see it under bucket or source or anywhere. Did I miss any steps ?
Sadik
Hello @Siddigburhan,
I’d actually recommend holding off on upgrading until 3.x OSS is out later this year.
That way you dont’ have to learn Flux for no reason.
You can just port over your influxql queries and reap the significant performance benefits:
Hello Anaisdg
Thanks for your replay. I able to upgrade successfully from old version 1.5 to 2.7. I logged in and I can see all the databases ended with database name/autogen. For example : xxx/autogen.
Why it is end with autogen?
Can I remove it or is there any way to show only the database name without the autogen.
Thanks and Regards
