hello, first time caller.
I had just attempted to upgrade InfluxDB 1.8 that had been running quite happily for over a year to Influx 2.02.
Here is what I did:
I downloaded the .deb from the influxdata site and installed it over the original influx.
I then did systemctl daemon-reload and stopped influx.
The I performed influx upgrade, which seemed to run ok, I could see it stating it was upgrading my databases. For example from upgrade.log:
{“level”:“info”,“ts”:1606134641.2682717,“caller”:“upgrade/database.go:156”,“msg”:“Copying data”,“source”:“/var/lib/
influxdb/data/telegraf/autogen”,“target”:“/root/.influxdbv2/engine/data/2f0d22a60fc5872e/autogen”}
{“level”:“info”,“ts”:1606134677.8064325,“caller”:“upgrade/database.go:171”,“msg”:“Copying wal”,“source”:“/var/lib/i
nfluxdb/wal/telegraf/autogen”,“target”:“/root/.influxdbv2/engine/wal/2f0d22a60fc5872e/autogen”}
{“level”:“info”,“ts”:1606134678.0923033,“caller”:“upgrade/database.go:80”,“msg”:"Upgrading database ",“database”:“s
peedtest”}
Then I logged into http://localhost:8086 and the only bucket I can see is the new one I created at the beginning of the upgrade.
No sign of any of my data…
I must say, thats not an ideal upgrade process.
Am I missing something?
