I encounter a few issues during the upgrade process of my influxdb docker 1.8 to 2.0.4
in the upgrade.log all is ok
{“level”:“info”,“ts”:1616033352.2994857,“caller”:“upgrade/upgrade.go:395”,“msg”:“Starting InfluxDB 1.x upgrade”}
{“level”:“info”,“ts”:1616033352.2999074,“caller”:“upgrade/upgrade.go:398”,“msg”:“Upgrading config file”,“file”:“/etc/influxdb/influxdb.conf”}
{“level”:“info”,“ts”:1616033352.39868,“caller”:“upgrade/upgrade.go:402”,“msg”:“Config file upgraded.”,“1.x config”:“/etc/influxdb/influxdb.conf”,“2.x config”:“/etc/influxdb2/config.toml”}
{“level”:“info”,“ts”:1616033352.3988657,“caller”:“upgrade/upgrade.go:412”,“msg”:“Upgrade source paths”,“meta”:“/var/lib/influxdb/meta”,“data”:“/var/lib/influxdb/data”}
{“level”:“info”,“ts”:1616033352.3990054,“caller”:“upgrade/upgrade.go:413”,“msg”:“Upgrade target paths”,“bolt”:“/var/lib/influxdb2/influxd.bolt”,“engine”:“/var/lib/influxdb2/engine”}
{“level”:“info”,“ts”:1616033352.5881813,“caller”:“bolt/bbolt.go:76”,“msg”:“Resources opened”,“service”:“bolt”,“path”:“/var/lib/influxdb2/influxd.bolt”}
{“level”:“info”,“ts”:1616033352.6661072,“caller”:“migration/migration.go:153”,“msg”:“Bringing up metadata migrations”,“service”:“migrations”,“migration_count”:14}
{“level”:“info”,“ts”:1616033362.1642268,“caller”:“upgrade/setup.go:148”,“msg”:“CLI config has been stored.”,“path”:“/etc/influxdb2/influx-configs”}
{“level”:“info”,“ts”:1616033362.164388,“caller”:“upgrade/database.go:201”,“msg”:“Checking available disk space”}
{“level”:“info”,“ts”:1616033363.0342376,“caller”:“upgrade/database.go:222”,“msg”:“Computed disk space”,“free”:“2.3 TB”,“required”:“1.6 GB”}
{“level”:“info”,“ts”:1616033363.0881262,“caller”:“upgrade/database.go:51”,“msg”:“Upgrading databases”}
{“level”:“warn”,“ts”:1616033458.8931978,“caller”:“upgrade/database.go:157”,“msg”:“Empty retention policy”}
{“level”:“info”,“ts”:1616033473.4203157,“caller”:“upgrade/database.go:194”,“msg”:“Database upgrade complete”,“upgraded_count”:4}
{“level”:“info”,“ts”:1616033473.4777935,“caller”:“upgrade/security.go:30”,“msg”:“There are no users in 1.x, nothing to upgrade”}
{“level”:“info”,“ts”:1616033473.47907,“caller”:“upgrade/upgrade.go:482”,“msg”:“Upgrade successfully completed. Start the influxd service now, then log in”,“login_url”:"http://localhost:8086"}
but the container crash with an exit code 1 and I have a lot of this line in my container log
rm: cannot remove ‘/var/lib/influxdb2/engine/data/4d18dcaf0212e7bd/autogen/336/index/4’: Directory not empty
rm: cannot remove ‘/var/lib/influxdb2/engine/data/4d18dcaf0212e7bd/autogen/336/index/5’: Directory not empty
rm: cannot remove ‘/var/lib/influxdb2/engine/data/4d18dcaf0212e7bd/autogen/336/index/3’: Directory not empty
rm: cannot remove ‘/var/lib/influxdb2/engine/data/4d18dcaf0212e7bd/autogen/336/index/6’: Directory not empty
rm: cannot remove ‘/var/lib/influxdb2/engine/data/4d18dcaf0212e7bd/_series/06’: Directory not empty
rm: cannot remove ‘/var/lib/influxdb2/engine/data/4d18dcaf0212e7bd/_series/05’: Directory not empty
When restarting the upgrade process restart and crash in the same way
My parameters are:
| DOCKER_INFLUXDB_INIT_USERNAME | myuser |
| DOCKER_INFLUXDB_INIT_PASSWORD | mypassword |
| DOCKER_INFLUXDB_INIT_ORG | myorg |
| DOCKER_INFLUXDB_INIT_BUCKET | init-bucket |
| DOCKER_INFLUXDB_INIT_UPGRADE_V1_CONFIG | /etc/influxdb/influxdb.conf |
| DOCKER_INFLUXDB_INIT_UPGRADE_V1_DIR | /var/lib/influxdb |
| PATH | /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin |
| GOSU_VER | 1.12 |
| INFLUXDB_VERSION | 2.0.4 |
| INFLUX_CONFIGS_PATH | /etc/influxdb2/influx-configs |
| INFLUXD_INIT_PORT | 9999 |
| DOCKER_INFLUXDB_INIT_MODE | upgrade |
