Failed Docker Migration from Influx 1.8 to 2.7 without information
Hi everybody!
I’m trying to upgrade my influx image from 1.8 to 2.7 using the Docker upgrade option, but process stops everytime.
I don’t see any resource saturation like CPU or RAM and the only information that I see are the following logs:
{"level":"info","ts":1708447564.151024,"caller":"upgrade/upgrade.go:401","msg":"Starting InfluxDB 1.x upgrade"}
{"level":"info","ts":1708447564.1510768,"caller":"upgrade/upgrade.go:404","msg":"Upgrading config file","file":"/etc/influxdb/influxdb.conf"}
{"level":"info","ts":1708447564.151148,"caller":"upgrade/upgrade.go:408","msg":"Config file upgraded.","1.x config":"/etc/influxdb/influxdb.conf","2.x config":"/etc/influxdb2/config.toml"}
{"level":"info","ts":1708447564.1511612,"caller":"upgrade/upgrade.go:418","msg":"Upgrade source paths","meta":"/var/lib/influxdb/volume/meta","data":"/var/lib/influxdb/volume/data"}
{"level":"info","ts":1708447564.151177,"caller":"upgrade/upgrade.go:419","msg":"Upgrade target paths","bolt":"/var/lib/influxdb2/influxd.bolt","engine":"/var/lib/influxdb2/engine"}
{"level":"info","ts":1708447564.1599119,"caller":"bolt/bbolt.go:83","msg":"Resources opened","service":"bolt","path":"/var/lib/influxdb2/influxd.bolt"}
{"level":"info","ts":1708447564.1613262,"caller":"migration/migration.go:175","msg":"Bringing up metadata migrations","service":"migrations","migration_count":20}
{"level":"info","ts":1708447564.396699,"caller":"upgrade/setup.go:73","msg":"CLI config has been stored.","path":"/etc/influxdb2/influx-configs"}
{"level":"info","ts":1708447564.3967407,"caller":"upgrade/database.go:202","msg":"Checking available disk space"}
{"level":"info","ts":1708447564.397583,"caller":"upgrade/database.go:223","msg":"Computed disk space","free":"63 GB","required":"45 GB"}
{"level":"info","ts":1708447564.3976183,"caller":"upgrade/database.go:51","msg":"Upgrading databases"}
{"level":"info","ts":1708447564.4023683,"caller":"upgrade/database.go:101","msg":"Creating mapping","database":"default","retention policy":"defaul","orgID":"example","bucketID":"example"}
2024-02-20T16:47:33. warn cleaning bolt and engine files to prevent conflicts on retry {"system": "docker", "bolt_path": "/var/lib/influxdb2/influxd.bolt", "engine_path": "/var/lib/influxdb2/engine"}
It seems that the issue is related to the volume size since the same procedure on a database of 10GB was successful.
Any ideas?
I have performed the migration on debug mode with INFLUXD_LOG_LEVEL environment variable, but I don’t see any critical log.
{"level":"info","ts":1708452939.8188407,"caller":"upgrade/upgrade.go:401","msg":"Starting InfluxDB 1.x upgrade"}
{"level":"info","ts":1708452939.818899,"caller":"upgrade/upgrade.go:404","msg":"Upgrading config file","file":"/etc/influxdb/influxdb.conf"}
{"level":"info","ts":1708452939.8189814,"caller":"upgrade/upgrade.go:408","msg":"Config file upgraded.","1.x config":"/etc/influxdb/influxdb.conf","2.x config":"/etc/influxdb2/config.toml"}
{"level":"info","ts":1708452939.8189976,"caller":"upgrade/upgrade.go:418","msg":"Upgrade source paths","meta":"/var/lib/influxdb/volume/meta","data":"/var/lib/influxdb/volume/data"}
{"level":"info","ts":1708452939.819011,"caller":"upgrade/upgrade.go:419","msg":"Upgrade target paths","bolt":"/var/lib/influxdb2/influxd.bolt","engine":"/var/lib/influxdb2/engine"}
{"level":"info","ts":1708452939.8291152,"caller":"bolt/bbolt.go:83","msg":"Resources opened","service":"bolt","path":"/var/lib/influxdb2/influxd.bolt"}
{"level":"info","ts":1708452939.8304136,"caller":"migration/migration.go:175","msg":"Bringing up metadata migrations","service":"migrations","migration_count":20}
{"level":"debug","ts":1708452939.8304374,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"initial migration","target_state":"up","migration_event":"started"}
{"level":"debug","ts":1708452939.8861432,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"initial migration","target_state":"up","migration_event":"completed"}
{"level":"debug","ts":1708452939.8861682,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"add index \"userresourcemappingsbyuserindexv1\"","target_state":"up","migration_event":"started"}
{"level":"debug","ts":1708452939.8897743,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"add index \"userresourcemappingsbyuserindexv1\"","target_state":"up","migration_event":"completed"}
{"level":"debug","ts":1708452939.8897972,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"migrate task owner id","target_state":"up","migration_event":"started"}
{"level":"debug","ts":1708452939.8920665,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"migrate task owner id","target_state":"up","migration_event":"completed"}
{"level":"debug","ts":1708452939.8920867,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"create DBRP buckets","target_state":"up","migration_event":"started"}
{"level":"debug","ts":1708452939.8986511,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"create DBRP buckets","target_state":"up","migration_event":"completed"}
{"level":"debug","ts":1708452939.8986921,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"create pkger stacks buckets","target_state":"up","migration_event":"started"}
{"level":"debug","ts":1708452939.9080582,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"create pkger stacks buckets","target_state":"up","migration_event":"completed"}
{"level":"debug","ts":1708452939.9080744,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"delete sessionsv1 bucket","target_state":"up","migration_event":"started"}
{"level":"debug","ts":1708452939.914051,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"delete sessionsv1 bucket","target_state":"up","migration_event":"completed"}
{"level":"debug","ts":1708452939.9140654,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"Create TSM metadata buckets","target_state":"up","migration_event":"started"}
{"level":"debug","ts":1708452939.918674,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"Create TSM metadata buckets","target_state":"up","migration_event":"completed"}
{"level":"debug","ts":1708452939.918691,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"Create Legacy authorization buckets","target_state":"up","migration_event":"started"}
{"level":"debug","ts":1708452939.9245334,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"Create Legacy authorization buckets","target_state":"up","migration_event":"completed"}
{"level":"debug","ts":1708452939.9245477,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"Create legacy auth password bucket","target_state":"up","migration_event":"started"}
{"level":"debug","ts":1708452939.9286199,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"Create legacy auth password bucket","target_state":"up","migration_event":"completed"}
{"level":"debug","ts":1708452939.928639,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"add index \"telegrafbyorgindexv1\"","target_state":"up","migration_event":"started"}
{"level":"debug","ts":1708452939.933135,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"add index \"telegrafbyorgindexv1\"","target_state":"up","migration_event":"completed"}
{"level":"debug","ts":1708452939.933152,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"populate dashboards owner id","target_state":"up","migration_event":"started"}
{"level":"debug","ts":1708452939.9365034,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"populate dashboards owner id","target_state":"up","migration_event":"completed"}
{"level":"debug","ts":1708452939.9365447,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"add index \"dbrpbyorgv1\"","target_state":"up","migration_event":"started"}
{"level":"debug","ts":1708452939.9414568,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"add index \"dbrpbyorgv1\"","target_state":"up","migration_event":"completed"}
{"level":"debug","ts":1708452939.941475,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"repair DBRP owner and bucket IDs","target_state":"up","migration_event":"started"}
{"level":"debug","ts":1708452939.9443226,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"repair DBRP owner and bucket IDs","target_state":"up","migration_event":"completed"}
{"level":"debug","ts":1708452939.9443405,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"add index \"dbrpbyorgv1\"","target_state":"up","migration_event":"started"}
{"level":"debug","ts":1708452939.948634,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"add index \"dbrpbyorgv1\"","target_state":"up","migration_event":"completed"}
{"level":"debug","ts":1708452939.948658,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"record shard group durations in bucket metadata","target_state":"up","migration_event":"started"}
{"level":"debug","ts":1708452939.9511344,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"record shard group durations in bucket metadata","target_state":"up","migration_event":"completed"}
{"level":"debug","ts":1708452939.9511576,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"add annotations and notebooks resource types to operator token","target_state":"up","migration_event":"started"}
{"level":"debug","ts":1708452939.9548705,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"add annotations and notebooks resource types to operator token","target_state":"up","migration_event":"completed"}
{"level":"debug","ts":1708452939.954886,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"add annotations and notebooks resource types to all-access tokens","target_state":"up","migration_event":"started"}
{"level":"debug","ts":1708452939.958519,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"add annotations and notebooks resource types to all-access tokens","target_state":"up","migration_event":"completed"}
{"level":"debug","ts":1708452939.958532,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"repair missing shard group durations","target_state":"up","migration_event":"started"}
{"level":"debug","ts":1708452939.961096,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"repair missing shard group durations","target_state":"up","migration_event":"completed"}
{"level":"debug","ts":1708452939.9611104,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"add remotes and replications resource types to operator and all-access tokens","target_state":"up","migration_event":"started"}
{"level":"debug","ts":1708452939.9656513,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"add remotes and replications resource types to operator and all-access tokens","target_state":"up","migration_event":"completed"}
{"level":"debug","ts":1708452939.965666,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"create remotes and replications metrics buckets","target_state":"up","migration_event":"started"}
{"level":"debug","ts":1708452939.9713132,"caller":"migration/migration.go:294","msg":"Executing metadata migration","service":"migrations","migration_name":"create remotes and replications metrics buckets","target_state":"up","migration_event":"completed"}
{"level":"debug","ts":1708452939.9777346,"caller":"tenant/middleware_user_logging.go:36","msg":"user create","store":"new","took":0.001771084}
{"level":"debug","ts":1708452940.0416768,"caller":"tenant/middleware_user_logging.go:137","msg":"set password","store":"new","took":0.063904592}
{"level":"debug","ts":1708452940.0433817,"caller":"tenant/middleware_org_logging.go:48","msg":"org find by ID","store":"new","took":0.000021206}
{"level":"debug","ts":1708452940.044672,"caller":"tenant/middleware_bucket_logging.go:35","msg":"bucket create","store":"new","took":0.00131354}
{"level":"debug","ts":1708452940.0461304,"caller":"tenant/middleware_org_logging.go:48","msg":"org find by ID","store":"new","took":0.000024085}
{"level":"debug","ts":1708452940.0477734,"caller":"tenant/middleware_bucket_logging.go:35","msg":"bucket create","store":"new","took":0.001668193}
{"level":"debug","ts":1708452940.050733,"caller":"tenant/middleware_urm_logging.go:35","msg":"urm create","store":"new","took":0.001653261}
{"level":"debug","ts":1708452940.050761,"caller":"tenant/middleware_org_logging.go:35","msg":"org create","store":"new","took":0.009048714}
{"level":"debug","ts":1708452940.052243,"caller":"tenant/middleware_urm_logging.go:35","msg":"urm create","store":"new","took":0.001474157}
{"level":"debug","ts":1708452940.0522773,"caller":"tenant/middleware_org_logging.go:48","msg":"org find by ID","store":"new","took":0.000019279}
{"level":"debug","ts":1708452940.0536025,"caller":"tenant/middleware_bucket_logging.go:35","msg":"bucket create","store":"new","took":0.001345289}
{"level":"debug","ts":1708452940.055023,"caller":"tenant/middleware_user_logging.go:49","msg":"user find by ID","store":"new","took":0.000017114}
{"level":"debug","ts":1708452940.0550513,"caller":"tenant/middleware_org_logging.go:48","msg":"org find by ID","store":"new","took":0.000012126}
{"level":"info","ts":1708452940.0566823,"caller":"upgrade/setup.go:73","msg":"CLI config has been stored.","path":"/etc/influxdb2/influx-configs"}
{"level":"info","ts":1708452940.056709,"caller":"upgrade/database.go:202","msg":"Checking available disk space"}
{"level":"info","ts":1708452940.1959965,"caller":"upgrade/database.go:223","msg":"Computed disk space","free":"84 GB","required":"61 GB"}
{"level":"info","ts":1708452940.196074,"caller":"upgrade/database.go:51","msg":"Upgrading databases"}
{"level":"debug","ts":1708452940.196092,"caller":"upgrade/database.go:61","msg":"Upgrading database","database":"default"}
{"level":"debug","ts":1708452940.1961148,"caller":"upgrade/database.go:78","msg":"Creating bucket","Bucket":"default/default"}
{"level":"debug","ts":1708452940.1961937,"caller":"tenant/middleware_org_logging.go:48","msg":"org find by ID","store":"new","took":0.000059863}
{"level":"debug","ts":1708452940.1992478,"caller":"tenant/middleware_bucket_logging.go:35","msg":"bucket create","store":"new","took":0.003116858}
{"level":"debug","ts":1708452940.1992679,"caller":"upgrade/database.go:86","msg":"Creating database with retention policy","database":"0ad7fe2569a13c50"}
{"level":"info","ts":1708452940.201298,"caller":"upgrade/database.go:101","msg":"Creating mapping","database":"default","retention policy":"default","orgID":"6014d19dad0048ea","bucketID":"0ad7fe2569a13c50"}
{"level":"debug","ts":1708452940.201385,"caller":"tenant/middleware_bucket_logging.go:48","msg":"bucket find by ID","store":"new","took":0.000057113}
{"level":"debug","ts":1708452940.2014256,"caller":"tenant/middleware_bucket_logging.go:45","msg":"failed to find bucket with ID 0c9dee1b6a6ff000","store":"new","error":"bucket not found","took":0.000010195}
{"level":"debug","ts":1708452940.2030492,"caller":"upgrade/database.go:114","msg":"Creating shard group","database":"0ad7fe2569a13c50","retention policy":"autogen","time":1698624000}
{"level":"debug","ts":1708452940.204596,"caller":"upgrade/database.go:114","msg":"Creating shard group","database":"0ad7fe2569a13c50","retention policy":"autogen","time":1699228800}
{"level":"debug","ts":1708452940.205893,"caller":"upgrade/database.go:114","msg":"Creating shard group","database":"0ad7fe2569a13c50","retention policy":"autogen","time":1699833600}
{"level":"debug","ts":1708452940.2072716,"caller":"upgrade/database.go:114","msg":"Creating shard group","database":"0ad7fe2569a13c50","retention policy":"autogen","time":1700438400}
{"level":"debug","ts":1708452940.2088203,"caller":"upgrade/database.go:114","msg":"Creating shard group","database":"0ad7fe2569a13c50","retention policy":"autogen","time":1701043200}
{"level":"debug","ts":1708452940.2102702,"caller":"upgrade/database.go:114","msg":"Creating shard group","database":"0ad7fe2569a13c50","retention policy":"autogen","time":1701648000}
{"level":"debug","ts":1708452940.2117949,"caller":"upgrade/database.go:114","msg":"Creating shard group","database":"0ad7fe2569a13c50","retention policy":"autogen","time":1702252800}
{"level":"debug","ts":1708452940.2131066,"caller":"upgrade/database.go:114","msg":"Creating shard group","database":"0ad7fe2569a13c50","retention policy":"autogen","time":1702857600}
{"level":"debug","ts":1708452940.2146516,"caller":"upgrade/database.go:114","msg":"Creating shard group","database":"0ad7fe2569a13c50","retention policy":"autogen","time":1703462400}
{"level":"debug","ts":1708452940.2162488,"caller":"upgrade/database.go:114","msg":"Creating shard group","database":"0ad7fe2569a13c50","retention policy":"autogen","time":1704067200}
{"level":"debug","ts":1708452940.2176363,"caller":"upgrade/database.go:114","msg":"Creating shard group","database":"0ad7fe2569a13c50","retention policy":"autogen","time":1704672000}
{"level":"debug","ts":1708452940.218943,"caller":"upgrade/database.go:114","msg":"Creating shard group","database":"0ad7fe2569a13c50","retention policy":"autogen","time":1705276800}
{"level":"debug","ts":1708452940.2205255,"caller":"upgrade/database.go:114","msg":"Creating shard group","database":"0ad7fe2569a13c50","retention policy":"autogen","time":1705881600}
{"level":"debug","ts":1708452940.2219942,"caller":"upgrade/database.go:114","msg":"Creating shard group","database":"0ad7fe2569a13c50","retention policy":"autogen","time":1706486400}
{"level":"debug","ts":1708452940.2236526,"caller":"upgrade/database.go:114","msg":"Creating shard group","database":"0ad7fe2569a13c50","retention policy":"autogen","time":1707091200}
{"level":"debug","ts":1708452940.2249715,"caller":"upgrade/database.go:114","msg":"Creating shard group","database":"0ad7fe2569a13c50","retention policy":"autogen","time":1707696000}
{"level":"debug","ts":1708452940.2265859,"caller":"upgrade/database.go:114","msg":"Creating shard group","database":"0ad7fe2569a13c50","retention policy":"autogen","time":1708300800}
{"level":"debug","ts":1708452940.2277763,"caller":"upgrade/database.go:129","msg":"Copying data","source":"/var/lib/influxdb/volume/data/default/default","target":"/var/lib/influxdb2/engine/data/0ad7fe2569a13c50/autogen"}
2024-02-20T18:16:59.	warn	cleaning bolt and engine files to prevent conflicts on retry	{"system": "docker", "bolt_path": "/var/lib/influxdb2/influxd.bolt", "engine_path": "/var/lib/influxdb2/engine"}
I didn’t mention it, but I was running the docker image in Kubernetes.
It seems that the root cause was the Liveness Probe timeout, it was too low interrupting the upgrade
@Aurelio_Marin_Aranza thanks so much for sharing your solution with the community. I’m sure they’ll appreciate it. Out of curiosity what are you doing with InfluxDB?
