I am pleased to announce the release of Telegraf 1.5.1. This is a support release and contains the following bug fixes:
- #3624: Fix name error in jolokia2_agent sample config.
- #3625: Fix DC/OS login expiration time.
- #3593: Set Content-Type charset in influxdb output and allow it be overridden.
- #3594: Document permissions setup for postfix input.
- #3633: Fix deliver_get field in rabbitmq input.
- #3607: Escape environment variables during config toml parsing.
Official packages are available from the downloads page or via github.
- https://dl.influxdata.com/telegraf/releases/telegraf_1.5.1-1_amd64.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.5.1-1.x86_64.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.5.1_windows_amd64.zip
- https://dl.influxdata.com/telegraf/releases/telegraf-1.5.1_freebsd_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.5.1-static_linux_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.5.1_linux_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf_1.5.1-1_i386.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.5.1-1.i386.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.5.1_windows_i386.zip
- https://dl.influxdata.com/telegraf/releases/telegraf-1.5.1_freebsd_i386.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.5.1_linux_i386.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf_1.5.1-1_arm64.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.5.1-1.arm64.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.5.1_linux_arm64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf_1.5.1-1_armhf.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.5.1_linux_armhf.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf_1.5.1-1_armel.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.5.1-1.armel.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.5.1_linux_armel.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.5.1-1.armv6hl.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf_1.5.1-1_s390x.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.5.1-1.s390x.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.5.1_linux_s390x.tar.gz
