I am pleased to announce the release of Telegraf 1.3.5.
This release contains several important fixes:
- #3049: Fix prometheus output cannot be reloaded.
- #3037: Fix filestat reporting exists when cannot list directory.
- #2386: Fix ntpq parse issue when using dns_lookup.
- #2554: Fix panic when agent.interval = “0s”.
Official packages are available from the downloads page or using the direct links below:
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.5-1_amd64.deb
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.5-1_arm64.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.5-1.arm64.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.5-1_armel.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.5-1.armel.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.5-1_armhf.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.5-1.armv6hl.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.5-1_i386.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.5-1.i386.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.5-1.x86_64.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.5_freebsd_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.5_freebsd_i386.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.5_linux_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.5_linux_arm64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.5_linux_armel.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.5_linux_armhf.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.5_linux_i386.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.5-static_linux_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.5_windows_amd64.zip
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.5_windows_i386.zip
