I am pleased to announce the release of Telegraf 1.3.2.
This release contains several important fixes:
- #2862: Fix InfluxDB UDP metric splitting.
- #2888: Fix mongodb/leofs urls without scheme.
- #2822: Fix inconsistent label dimensions in prometheus output.
Official packages are available from the downloads page or using the direct links below:
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.2-1_amd64.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.2-1.x86_64.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.2-1_arm64.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.2-1.arm64.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.2-1_armel.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.2-1.armel.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.2-1_armhf.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.2-1.armv6hl.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.2-1_i386.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.2-1.i386.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.2_freebsd_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.2_freebsd_i386.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.2_linux_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.2_linux_arm64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.2_linux_armel.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.2_linux_armhf.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.2_linux_i386.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.2-static_linux_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.2_windows_amd64.zip
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.2_windows_i386.zip
