I am pleased to announce the release of Telegraf 1.3.3.
This release contains several important fixes:
- #2915: Allow dos line endings in tail and logparser.
- #2937: Remove label value sanitization in prometheus output.
- #2948: Fix bug parsing default timestamps with modified precision.
- #2954: Fix panic in elasticsearch input if cannot determine master.
Official packages are available from the downloads page or using the direct links below:
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.3-1_amd64.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.3-1.x86_64.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.3-1_arm64.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.3-1.arm64.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.3-1_armel.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.3-1.armel.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.3-1_armhf.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.3-1.armv6hl.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.3-1_i386.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.3-1.i386.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.3_freebsd_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.3_freebsd_i386.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.3_linux_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.3_linux_arm64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.3_linux_armel.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.3_linux_armhf.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.3_linux_i386.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.3-static_linux_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.3_windows_amd64.zip
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.3_windows_i386.zip
