I am pleased to announce the release of Telegraf 1.4.3.
This release contains several important fixes:
- #3327: Fix container name filters in docker input.
- #3321: Fix snmpwalk address format in leofs input.
- #3329: Fix case sensitivity issue in sqlserver query.
- #3342: Fix CPU input plugin stuck after suspend on Linux.
- #3013: Fix mongodb input panic when restarting mongodb.
- #3224: Preserve url path prefix in influx output.
- #3354: Fix TELEGRAF_OPTS expansion in systemd service unit.
- #3357: Remove warning when JSON contains null value.
- #3375: Fix ACL token usage in consul input plugin.
- #3369: Fix unquoting error with Tomcat 6.
- #3373: Fix syscall panic in diskio on some Linux systems.
Official packages are available from the downloads page or via github.
- https://dl.influxdata.com/telegraf/releases/telegraf_1.4.3-1_amd64.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.3-1.x86_64.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.3_windows_amd64.zip
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.3_freebsd_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.3-static_linux_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.3_linux_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf_1.4.3-1_i386.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.3-1.i386.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.3_windows_i386.zip
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.3_freebsd_i386.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.3_linux_i386.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf_1.4.3-1_arm64.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.3-1.arm64.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.3_linux_arm64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf_1.4.3-1_armhf.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.3_linux_armhf.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf_1.4.3-1_armel.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.3-1.armel.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.3_linux_armel.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.3-1.armv6hl.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf_1.4.3-1_s390x.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.3-1.s390x.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.3_linux_s390x.tar.gz
