I am pleased to announce the release of Telegraf 1.4.4.
This release contains several important fixes:
- #3401: Use schema specified in mqtt_consumer input.
- #3419: Redact datadog API key in log output.
- #3311: Fix error getting pids in netstat input.
- #3339: Support HOST_VAR envvar to locate /var in system input.
- #3383: Use current time if docker container read time is zero value.
Official packages are available from the downloads page or via github.
- https://dl.influxdata.com/telegraf/releases/telegraf_1.4.4-1_amd64.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.4-1.x86_64.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.4_windows_amd64.zip
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.4_freebsd_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.4-static_linux_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.4_linux_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf_1.4.4-1_i386.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.4-1.i386.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.4_windows_i386.zip
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.4_freebsd_i386.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.4_linux_i386.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf_1.4.4-1_arm64.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.4-1.arm64.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.4_linux_arm64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf_1.4.4-1_armhf.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.4_linux_armhf.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf_1.4.4-1_armel.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.4-1.armel.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.4_linux_armel.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.4-1.armv6hl.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf_1.4.4-1_s390x.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.4-1.s390x.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.4_linux_s390x.tar.gz
