I am pleased to announce the release of Telegraf 1.4.1.
This release contains several important fixes:
- #3167: Fix MQTT input exits if Broker is not available on startup.
- #3217: Fix optional field value conversions in fluentd input.
- #3227: Whitelist allowed char classes for opentsdb output.
- #3232: Fix counter and gauge metric types.
- #3235: Fix skipped line with empty target in iptables.
- #3175: Fix duplicate keys in perf counters sqlserver query.
- #3230: Fix panic in statsd p100 calculation.
- #3242: Fix arm64 packages contain 32-bit executable.
Official packages are available from the downloads page or via github.
- https://dl.influxdata.com/telegraf/releases/telegraf_1.4.1-1_amd64.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.1-1.x86_64.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.1_windows_amd64.zip
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.1_freebsd_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.1-static_linux_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.1_linux_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf_1.4.1-1_i386.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.1-1.i386.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.1_windows_i386.zip
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.1_freebsd_i386.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.1_linux_i386.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf_1.4.1-1_arm64.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.1-1.arm64.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.1_linux_arm64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf_1.4.1-1_armhf.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.1_linux_armhf.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf_1.4.1-1_armel.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.1-1.armel.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.1_linux_armel.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.1-1.armv6hl.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf_1.4.1-1_s390x.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.1-1.s390x.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.1_linux_s390x.tar.gz
