I am pleased to announce the release of Telegraf 1.3.4.
This release contains several important fixes:
- #3001: Fix handling of escape characters within fields.
- #2988: Fix chrony plugin does not track system time offset.
- #3004: Do not allow metrics with trailing slashes.
- #3011: Prevent Write from being called concurrently.
Official packages are available from the downloads page or using the direct links below:
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.4-1_amd64.deb
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.4-1_arm64.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.4-1.arm64.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.4-1_armel.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.4-1.armel.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.4-1_armhf.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.4-1.armv6hl.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.4-1_i386.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.4-1.i386.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.4-1.x86_64.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.4_freebsd_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.4_freebsd_i386.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.4_linux_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.4_linux_arm64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.4_linux_armel.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.4_linux_armhf.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.4_linux_i386.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.4-static_linux_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.4_windows_amd64.zip
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.4_windows_i386.zip
