I am pleased to announce the release of Telegraf 1.4.2.
This release contains several important fixes:
- #3259: Fix error if int larger than 32-bit in /proc/vmstat.
- #3265: Fix parsing of JSON with a UTF8 BOM in httpjson.
- #2887: Allow JSON data format to contain zero metrics.
- #3284: Fix format of connection_timeout in mqtt_consumer.
- #3081: Fix case sensitivity error in sqlserver input.
- #3297: Add support for proxy environment variables to http_response.
- #1588: Add support for standard proxy env vars in outputs.
- #3282: Fix panic in cpu input if number of cpus changes.
- #2854: Use chunked transfer encoding in InfluxDB output.
Official packages are available from the downloads page or via github.
- https://dl.influxdata.com/telegraf/releases/telegraf_1.4.2-1_amd64.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.2-1.x86_64.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.2_windows_amd64.zip
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.2_freebsd_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.2-static_linux_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.2_linux_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf_1.4.2-1_i386.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.2-1.i386.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.2_windows_i386.zip
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.2_freebsd_i386.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.2_linux_i386.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf_1.4.2-1_arm64.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.2-1.arm64.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.2_linux_arm64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf_1.4.2-1_armhf.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.2_linux_armhf.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf_1.4.2-1_armel.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.2-1.armel.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.2_linux_armel.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.2-1.armv6hl.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf_1.4.2-1_s390x.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.2-1.s390x.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.4.2_linux_s390x.tar.gz
