Telegraf 1.3.1 is now available, this release contains fixes fixes for several bugs:
- #2749: Fixed sqlserver input to work with case sensitive server collation.
- #2782: Reuse transports in input plugins
- #2815: Inputs processes fails with “no such process”.
- #2851: Fix InfluxDB output database quoting.
- #2856: Fix net input on older Linux kernels.
- #2848: Fix panic in mongo input.
- #2869: Fix length calculation of split metric buffer.
Official packages are available from the downloads page, in the apt and yum repositories, or using the direct links below:
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.1-1_amd64.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.1-1.x86_64.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.1-1_arm64.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.1-1.arm64.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.1-1_armel.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.1-1.armel.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.1-1_armhf.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.1-1.armv6hl.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf_1.3.1-1_i386.deb
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.1-1.i386.rpm
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.1_freebsd_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.1_freebsd_i386.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.1_linux_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.1_linux_arm64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.1_linux_armel.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.1_linux_armhf.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.1_linux_i386.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.1-static_linux_amd64.tar.gz
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.1_windows_amd64.zip
- https://dl.influxdata.com/telegraf/releases/telegraf-1.3.1_windows_i386.zip
