RabbitMQ Input Plugin for Telegraf: authentication issue?
Hello everybody!
I’m trying to connect to my local RabbitMQ node from Telegraf using the RabbitMQ Input Plugin but keep getting an error message:
[inputs.rabbitmq] Error in plugin: Wrong answer from rabbitmq. Probably auth issue
Any idea why this is happening? Or are you aware of some way I can get some more detailed information about what the underlying cause is?
Thanks! :smiley:
P.S. I’m able to login to RabbitMQ Management UI on http://localhost:15672/ using the same admin user. I can also successfully run curl -i -u admin:guest http://localhost:15672/api/vhosts from the command line and it returns information about my queues.
The surprsing thing is, If I login to the InfluxDB web UI I can see that Telegraf has added a large number of new RabbitMQ measurement tags and fields. It’s even scraped the names of my queues. But whenever I look at any of those measurements they all have a value of zero.
Apparently I was using a Docker image in which the all statistics/metrics in RabbitMQ Management UI are disabled. So after switching to the right Docker image I can now see RabbitMQ metrics if I login to the RabbitMQ Management UI on http://localhost:15672. A couple of minutes after that the RabbitMQ metrics finally started showing up in InfluxDB. :partying_face:
