Luv
1
The rabbitmq plugin is not working.
This is the error log in the telegraf.log file
Error in input [inputs.rabbitmq]: Errors encountered: Get 127.0.0.1:5672/api/queues: unsupported protocol scheme
This is the telegraf configuration,
[[inputs.rabbitmq]]
url = "127.0.0.1:5672"
The rabbitmq server is up and running. What is the reason behind this problem ?
This input uses the management plugin, once enabled this API is usually on port 15672.
Luv
3
I have enabled that plugin now,
So, we have to give the 15672 port in Telegraf.conf?
[[inputs.rabbitmq]]
url = "127.0.0.1:15672"
Luv
4
@daniel If that is the case, still I am not getting anything.
here is the full error now,
2017-05-01T20:30:10Z E! ERROR in input [inputs.rabbitmq]: Errors encountered: [Get127.0.0.1:15672/api/queues: unsupported protocol scheme ""], [Get 127.0.0.1:15672/api/overview: unsupported protocol scheme ""],
[Get 127.0.0.1:15672/api/nodes: unsupported protocol scheme ""]
Luv
5
I do a get response by this,
curl -u guest:guest 'http://localhost:15672/api/queues/'
A very large json, which I cannot post here
@Luv Try url = http://localhost:15672 You need the http in there.
Luv
7
Oh yeah & Oh no !!
I see, it was written url. Works perfectly now !!
