Hi All
I enabled [[inputs.kernel]] and [[inputs.kernel_vmstat]] input plugins on my telegraf conf file and i can see the metrics when i test the telegraf with this config file, but this metrics is not writing to influxdb, i can’t see them as measurement on my Influxdb UI but other metrics does. I can also write the data manually on Influx UI, which i copied kernel_vmstat and kernel fields from output of telegraf --test command. Which configuration should i check, can you help? Thanks.
