I had use the following command with indicates your web page and it does not work
to see who can help me.
/home/server# sudo openssl req -x509 -nodes -newkey rsa:2048 \
-keyout /etc/ssl/influxdb-selfsigned.key
-out /etc/ssl/influxdb-selfsigned.crt
-days 365
/home/server# cd /etc/ssl/
root@ubuntuoasis:/etc/ssl# ls
certs influxdb-selfsigned.crt influxdb-selfsigned.key openssl.cnf private
root@ubuntuoasis:/etc/ssl# sudo chmod 644 /etc/ssl/influxdb-selfsigned.crt
root@ubuntuoasis:/etc/ssl# sudo chmod 600 /etc/ssl/influxdb-selfsigned.key
root@ubuntuoasis:/etc/ssl# influxd --tls-cert=/etc/ssl/influxdb-selfsigned.crt
^[[D^[[D^[[D2021-09-28T11:16:49.187216Z info Welcome to InfluxDB {“log_id”: “0Ws1n1dG000”, “version”: “2.0.8”, “commit”: “e91d41810f”, “build_date”: “2021-08-13T18:22:30Z”}
2021-09-28T11:16:49.313723Z info Resources opened {“log_id”: “0Ws1n1dG000”, “service”: “bolt”, “path”: “/root/.influxdbv2/influxd.bolt”}
2021-09-28T11:16:49.318021Z info Bringing up metadata migrations {“log_id”: “0Ws1n1dG000”, “service”: “migrations”, “migration_count”: 15}
2021-09-28T11:16:49.561838Z info Using data dir {“log_id”: “0Ws1n1dG000”, “service”: “storage-engine”, “service”: “store”, “path”: “/root/.influxdbv2/engine/data”}
2021-09-28T11:16:49.561978Z info Compaction settings {“log_id”: “0Ws1n1dG000”, “service”: “storage-engine”, “service”: “store”, “max_concurrent_compactions”: 1, “throughput_bytes_per_second”: 50331648, “throughput_bytes_per_second_burst”: 50331648}
2021-09-28T11:16:49.562004Z info Open store (start) {“log_id”: “0Ws1n1dG000”, “service”: “storage-engine”, “service”: “store”, “op_name”: “tsdb_open”, “op_event”: “start”}
2021-09-28T11:16:49.562080Z info Open store (end) {“log_id”: “0Ws1n1dG000”, “service”: “storage-engine”, “service”: “store”, “op_name”: “tsdb_open”, “op_event”: “end”, “op_elapsed”: “0.075ms”}
2021-09-28T11:16:49.562112Z info Starting retention policy enforcement service {“log_id”: “0Ws1n1dG000”, “service”: “retention”, “check_interval”: “30m”}
2021-09-28T11:16:49.562139Z info Starting precreation service {“log_id”: “0Ws1n1dG000”, “service”: “shard-precreation”, “check_interval”: “10m”, “advance_period”: “30m”}
2021-09-28T11:16:49.562186Z info Starting query controller {“log_id”: “0Ws1n1dG000”, “service”: “storage-reads”, “concurrency_quota”: 1024, “initial_memory_bytes_quota_per_query”: 9223372036854775807, “memory_bytes_quota_per_query”: 9223372036854775807, “max_memory_bytes”: 0, “queue_size”: 1024}
2021-09-28T11:16:49.584443Z info Configuring InfluxQL statement executor (zeros indicate unlimited). {“log_id”: “0Ws1n1dG000”, “max_select_point”: 0, “max_select_series”: 0, “max_select_buckets”: 0}
2021-09-28T11:16:49.939998Z info Starting {“log_id”: “0Ws1n1dG000”, “service”: “telemetry”, “interval”: “8h”}
2021-09-28T11:16:49.941074Z error Failed to set up TCP listener {“log_id”: “0Ws1n1dG000”, “service”: “tcp-listener”, “addr”: “:8086”, “error”: “listen tcp :8086: bind: address already in use”}
Error: listen tcp :8086: bind: address already in use
See ‘influxd -h’ for help
root@ubuntuoasis:/etc/ssl# influxd --tls-cert=/etc/ssl/influxdb-selfsigned.crt --tls-key=/etc/ssl/influxdb-selfsigned.key
2021-09-28T11:17:50.019288Z info Welcome to InfluxDB {“log_id”: “0Ws1qkGl000”, “version”: “2.0.8”, “commit”: “e91d41810f”, “build_date”: “2021-08-13T18:22:30Z”}
2021-09-28T11:17:50.083342Z info Resources opened {“log_id”: “0Ws1qkGl000”, “service”: “bolt”, “path”: “/root/.influxdbv2/influxd.bolt”}
2021-09-28T11:17:50.121040Z info Using data dir {“log_id”: “0Ws1qkGl000”, “service”: “storage-engine”, “service”: “store”, “path”: “/root/.influxdbv2/engine/data”}
2021-09-28T11:17:50.121125Z info Compaction settings {“log_id”: “0Ws1qkGl000”, “service”: “storage-engine”, “service”: “store”, “max_concurrent_compactions”: 1, “throughput_bytes_per_second”: 50331648, “throughput_bytes_per_second_burst”: 50331648}
2021-09-28T11:17:50.121372Z info Open store (start) {“log_id”: “0Ws1qkGl000”, “service”: “storage-engine”, “service”: “store”, “op_name”: “tsdb_open”, “op_event”: “start”}
2021-09-28T11:17:50.121481Z info Open store (end) {“log_id”: “0Ws1qkGl000”, “service”: “storage-engine”, “service”: “store”, “op_name”: “tsdb_open”, “op_event”: “end”, “op_elapsed”: “0.167ms”}
2021-09-28T11:17:50.121524Z info Starting retention policy enforcement service {“log_id”: “0Ws1qkGl000”, “service”: “retention”, “check_interval”: “30m”}
2021-09-28T11:17:50.121544Z info Starting precreation service {“log_id”: “0Ws1qkGl000”, “service”: “shard-precreation”, “check_interval”: “10m”, “advance_period”: “30m”}
2021-09-28T11:17:50.121662Z info Starting query controller {“log_id”: “0Ws1qkGl000”, “service”: “storage-reads”, “concurrency_quota”: 1024, “initial_memory_bytes_quota_per_query”: 9223372036854775807, “memory_bytes_quota_per_query”: 9223372036854775807, “max_memory_bytes”: 0, “queue_size”: 1024}
2021-09-28T11:17:50.127801Z info Configuring InfluxQL statement executor (zeros indicate unlimited). {“log_id”: “0Ws1qkGl000”, “max_select_point”: 0, “max_select_series”: 0, “max_select_buckets”: 0}
2021-09-28T11:17:50.446747Z info Starting {“log_id”: “0Ws1qkGl000”, “service”: “telemetry”, “interval”: “8h”}
2021-09-28T11:17:50.446880Z error Failed to set up TCP listener {“log_id”: “0Ws1qkGl000”, “service”: “tcp-listener”, “addr”: “:8086”, “error”: “listen tcp :8086: bind: address already in use”}
