I’ve been trying to get InfluxDB to accept a self-signed certificate, but so for, no luck. I’ve been following instructions from here:
I created the cert and key with this command:
openssl req -x509 -nodes -newkey rsa:2048 -keyout influxdb-selfsigned.key -out influxdb-selfsigned.crt -days 9999 -config “C:\OpenSSL\openssl.cnf”
The config.yml file is as follows:
http-bind-address: “:8087”
tls-cert: influxdb-selfsigned.crt
tls-key: influxdb-selfsigned.key
Note, I made the bind port 8087 to ensure it was reading the configuration.
When I start influx from the command line, there are no error messages. Initially there were some TLS handshake errors, but those disappeared, I think when I added the crt and key to the configuration.
However, when I access the URL https://localhost:8087, chrome shows a “not secure” message and I have to click through warnings to get to the site.
To try to get Chrome to trust the certificate, - I followed the instructions from this site:
I exported the cert, then re-imported it as trusted.
However, I still get the “not secure” message in Chrome.
Also, the InfluxDB console shows this message:
info http: TLS handshake error from [::1]:63065: remote error: tls: unknown certificate {“log_id”: “0cKnmWB0000”, “service”: “http”}
Any ideas how to get the cert working?
