Activating TSL for Influxdb: Unclear doc + ssl version?
Hey, I’m using Ubuntu 20.04 on a Raspi:
I followed the documentation on enabling TSL encryption.
At first I followed all the points (1-3). Here I went on:
influxd \
--tls-cert="<path-to-crt>" \
--tls-key="<path-to-key>"
TSL wasn’t activated via that. The following message appeared:
error failed http listener {“log_id”: “0WPPR9r0000”, “error”: “listen tcp :8086: bind: address already in use”}
So I tried to stop the influxd service first and try it again:
influxd --tls-cert=”/etc/ssl/influxdb-selfsigned.crt” --tls-key=”/etc/ssl/influxdb-selfsigned.key”
I got the following messages:
error failed to load x509 key pair {“log_id”: “0WPWXznG000”, “error”: “open ”/etc/ssl/influxdb-selfsigned.crt”: no such file or directory”}
I removed the hyphn (maybe the doc is confusing here). That fixed the error above. Now the next thing appeared:
error failed to load x509 key pair {“log_id”: “0WPXHq8l000”, “error”: “open /etc/ssl/influxdb-selfsigned.key: permission denied”}
So I ran it with sudo:
Idk why though, since the file permissions were set according to the documentation.
sudo influxd --tls-cert=/etc/ssl/influxdb-selfsigned.crt --tls-key=/etc/ssl/influxdb-selfsigned.key
influxd seems to start and stays at the following line:
info Listening {“log_id”: “0WPXPDeG000”, “transport”: “https”, “addr”: “:8086”, “port”: 8086}
ssl seemed to work now. I stopped via Ctrl+C and assumed that SSL would have been correctly configured. Therefore I restarted the service and ran the line to check like the documentation suggested:
~$ curl -vk https://localhost:8086/api/v2/ping
Trying 127.0.0.1:8086…
TCP_NODELAY set
Connected to localhost (127.0.0.1) port 8086 (#0)
ALPN, offering h2
ALPN, offering http/1.1
successfully set certificate verify locations:
CAfile: /etc/ssl/certs/ca-certificates.crt
CApath: /etc/ssl/certs
TLSv1.3 (OUT), TLS handshake, Client hello (1):
error:1408F10B:SSL routines:ssl3_get_record:wrong version number
Closing connection 0
curl: (35) error:1408F10B:SSL routines:ssl3_get_record:wrong version number
Now I assume that ssl is fine, however curl uses a wrong version number for this.? Or do I have to adjust influxd to a minimum tsl-min-version like the documentation suggests?
I found a Stackoverflow entry to this issue, however I’m not quite sure what to do.
Fix here:
I added the following 2 lines to the config file ( /etc/influxdb/config.toml)
tls-cert = “/etc/ssl/influxdb-selfsigned.crt”
tls-key = “/etc/ssl/influxdb-selfsigned.key”
Furthermore I had to change the file permissions of the .crt and .key file).
I changed them via sudo chmod 0777 /etc/ssl/influxdb-selfsigned.crt
Same for the .key file.
Afterwards the server started and I had access to the stored database.
If you got ERR_SSL_KEY_USAGE_INCOMPATIBLE error from browser:
you may also see the following error from influxDB output:
msg="http: TLS handshake error from [::1]:50476:
remote error: tls: illegal parameter" log_id=0rqN8H_0000 service=http
Remove the following lines from san.cnf under [v3_req]
   keyUsage = keyEncipherment, dataEncipherment
   extendedKeyUsage = serverAuth
Then re-create the certificate again. Make sure you have tls-cert, tls-key as OP suggests.
