I’ve installed a full TICK stack on a raspberry. Telegraf, InfluxDB and Chronograf are working correctly.
Now I’ve just installed Kapacitor and make it start, with my local InfluDB being the default db :
Sep 08 19:59:26 d367deb systemd[1]: Started Time series data processing engine..
Sep 08 19:59:27 d367deb kapacitord[47]: '##:::'##::::'###::::'########:::::'###:::::'######::'####:'########::'#######::'########::
Sep 08 19:59:27 d367deb kapacitord[47]: ##::'##::::'## ##::: ##.... ##:::'## ##:::'##... ##:. ##::... ##..::'##.... ##: ##.... ##:
Sep 08 19:59:27 d367deb kapacitord[47]: ##:'##::::'##:. ##:: ##:::: ##::'##:. ##:: ##:::..::: ##::::: ##:::: ##:::: ##: ##:::: ##:
Sep 08 19:59:27 d367deb kapacitord[47]: #####::::'##:::. ##: ########::'##:::. ##: ##:::::::: ##::::: ##:::: ##:::: ##: ########::
Sep 08 19:59:27 d367deb kapacitord[47]: ##. ##::: #########: ##.....::: #########: ##:::::::: ##::::: ##:::: ##:::: ##: ##.. ##:::
Sep 08 19:59:27 d367deb kapacitord[47]: ##:. ##:: ##.... ##: ##:::::::: ##.... ##: ##::: ##:: ##::::: ##:::: ##:::: ##: ##::. ##::
Sep 08 19:59:27 d367deb kapacitord[47]: ##::. ##: ##:::: ##: ##:::::::: ##:::: ##:. ######::'####:::: ##::::. #######:: ##:::. ##:
Sep 08 19:59:27 d367deb kapacitord[47]: ..::::..::..:::::..::..:::::::::..:::::..:::......:::....:::::..::::::.......:::..:::::..::
Sep 08 19:59:27 d367deb kapacitord[47]: 2017/09/08 19:59:27 Using configuration at: /etc/kapacitor/kapacitor.conf
Sep 08 19:59:27 d367deb kapacitord[47]: [run] 2017/09/08 19:59:27 I! Kapacitor starting, version 1.3.1, branch master, commit 3b5512f7276483326577907803167e4bb213c613
Sep 08 19:59:27 d367deb kapacitord[47]: [run] 2017/09/08 19:59:27 I! Go version go1.7.5
Sep 08 19:59:27 d367deb kapacitord[47]: [srv] 2017/09/08 19:59:27 I! Kapacitor hostname: localhost
Sep 08 19:59:27 d367deb kapacitord[47]: [srv] 2017/09/08 19:59:27 I! ClusterID: ee48dd54-7bba-4bf1-a7b5-516e0573de8c ServerID: caf7769f-3935-4d8c-929a-a608b5c13022
Sep 08 19:59:27 d367deb kapacitord[47]: [task_master:main] 2017/09/08 19:59:27 I! opened
Sep 08 19:59:27 d367deb kapacitord[47]: [scrapers] 2017/09/08 19:59:27 I! [Starting target manager...]
Sep 08 19:59:27 d367deb kapacitord[47]: [httpd] 2017/09/08 19:59:27 I! Starting HTTP service
Sep 08 19:59:27 d367deb kapacitord[47]: [httpd] 2017/09/08 19:59:27 I! Authentication enabled: false
Sep 08 19:59:27 d367deb kapacitord[47]: [httpd] 2017/09/08 19:59:27 I! Listening on HTTP: [::]:9092
Sep 08 19:59:27 d367deb kapacitord[47]: [run] 2017/09/08 19:59:27 I! Listening for signals
which looked good, except when I go to chronograf, click on “Configure Kapacitor”, then click on “Connect”, absolutely nothing happens (no error, no warning, nothing) and nothing is written in /var/log/kapacitor as well.
What should I do from here ?
P.S. I’m I using the conf your provide in resin .io demo with default = true for my local InfluxDB :
