How to configure Editor+Log for Docker Kapacitor and Chronograf instance, it is always blank.
Locally installed instance of Kapacitor and Chronograf works fine.
Below image is from my local instance which works.
Hi @ajayanaj, Sorry for the late response! well sometimes it works.
Are you still looking for the solution?
You need to configure capacitor to enable logging.
It works but there is a huge lag.
Thanks for your input.
