Above is the error that i have received whenever i try to configure Kapacitor for Chronograph.
Kindly advice on how to encounter this.
Thank you
Is Kapacitor installed on the same host and running on port 9092?
Hi noah.
Yes i believe , Kapacitor is installed on the same host and running on port 9092.
I try to look into kapacitor.conf to solve this. but unable to find the solution.
please help.
root@vps193776://# sudo systemctl status kapacitor
● kapacitor.service - Time series data processing engine.
Loaded: loaded (/lib/systemd/system/kapacitor.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Tue 2018-07-24 03:12:33 EDT; 20h ag
o
Docs: GitHub - influxdata/kapacitor: Open source framework for processing, monitoring, and alerting on time series data
Process: 30054 ExecStart=/usr/bin/kapacitord -config /etc/kapacitor/kapacitor.conf $KAPA
CITOR_OPTS (code=exited, status=1/FAILURE)
Main PID: 30054 (code=exited, status=1/FAILURE)
Warning: Journal has been rotated since unit was started. Log output is incomplete or unav
ailable.
This is the error i get when i try to check the kapacitor status
i am getting the same thing, was working fine, but it just seemed to stop any suggestions?
Same for me, any feedback.
Following, i’m having the same issue
