Hello all,
Currently i would like doing experiment with kapacitor, but when i try it, the kapacitor is actually failed or error, restart doesn’t change anything, here is the status:
Redirecting to /bin/systemctl status kapacitor.service
● kapacitor.service - Time series data processing engine.
Loaded: loaded (/usr/lib/systemd/system/kapacitor.service; disabled; vendor preset: disabled)
Active: failed (Result: start-limit) since Fri 2019-09-27 10:55:47 WIB; 41min ago
Docs: GitHub - influxdata/kapacitor: Open source framework for processing, monitoring, and alerting on time series data
Process: 14765 ExecStart=/usr/bin/kapacitord -config /etc/kapacitor/kapacitor.conf $KAPACITOR_OPTS (code=exited, status=1/FAILURE)
Main PID: 14765 (code=exited, status=1/FAILURE)
is there anybody know how to solve this problem?
Thank you
