Updated influxdb to 2.7.6 from 2.4.0, now UI is not opening
As the title suggest, I upgraded influxdb to 2.7.6 by updating in docker-compose.yml file to 2.7.6. Now, the influxdb UI is not opening and I am not able to downgrade as well to 2.4.0. What should I do, the logs is not showing any error -
Edit now influxd downgrade command shows:
But, again after updating influxdb version to 2.4.0 in docker compose its not working correctly.
Update:
Influxdb saved already existing bolt and sqlite as backup, and used those to revert back to 2.4. Don’t recommend upgrading now.
Update 2:
Checked the data, although data is there in the server, I guess due to sqlite file, my previous data is not updating. Can anyone help on this?
Hello @Pratik_Das_Baghel,
I’m sorry I haven’t seen someone encounter this before.
Can you please create an issue here:
Thank you
