hello, i have telegraf already connected to the database but dont collecte metrics, if you have any solution share it
Do you happen to be using a 32-bit Windows? If so, I think you are running into this issue that prevents the win_perf_counters plugin from working in 32-bit Windows.
thank you daniel ,it’s working now
