Telegraf speed_test formatting
I was testing out the internet_speed plugin and it works for printing into InfluxDB but does not show up if sent to Victoria. I think it is due to the formatting of the output string and was curious if anyone has a suggestion how to reformat it before I write my own version instead? We are using the outputs.influxdb plugin.
Ignore this, it is working. I think my issue was not waiting long enough for it to trigger.
Hello @npm_engineer
Thanks for including your solution and for your questions!
