I am currently using the tail plugin from Telegraf to push InfluxDB line protocol data directly to InfluxDB. Have not fully scaled up yet but on a smaller test system I noticed there are occasionally a few measurements being recorded that seem to be incorrectly formatted/parsed. It looks like it took a partial cut of line protocol formatted line and used that as the new line, for example:
Real line -
ClientRequest,host=cassandraHost01,tagOne=valueOne,type=cassandra,name=ConditionNotMet,scope=CASRead field1=42,field2=100,field3=400 1644353580033000000
However I will notice something like the following as a series in InfluxDB -
So the measurement recorded in the DB is sandraHost01 with the tags and fields that followed, and the preceding bit (ClientRequest,host=cas) is lost.
Anyone know why this might be happening? My tail plugin config is this -
[[inputs.tail]]
files = ["/path/to/logs/telegraf-metrics*"]
data_format = "influx"
path_tag = ""
And my agent config is this -
[agent]
interval = "60s"
debug = false
hostname = "hostname"
round_interval = true
flush_interval = "60s"
flush_jitter = "0s"
collection_jitter = "0s"
metric_batch_size = 1000
metric_buffer_limit = 15000
quiet = false
logtarget = "file"
logfile = "/opt/telegraf.log"
logfile_rotation_interval = "24h"
logfile_rotation_max_size = "10MB"
logfile_rotation_max_archives = 5
omit_hostname = false
