Hello Everyone,
Im new here, I have an issue with one plugin,
So im using telegraf to get data from ipmi sensor, and it’s working I can see that in Grafana dashboard via InfluxDB,
so until here everything is working correctly,
I added another input plugin to my telegraf.conf : telegraf-speedtest/speedtest.conf at master · Derek-K/telegraf-speedtest · GitHub
Once im checking telegraf -test , I can see that the first plugin(ipmi sensor) is OK and second plugin (speedtest) is OK as well.
But speedtest measurements are not stored in the influxdb I check it using
root@d5c51db15460:/# influx -execute ‘show measurements’ -database ‘telegraph’
nameipmi_sensor
Here as you can see there is only the ipmi_sensor
Telegraf is restarted already, and both plugins are working with -test
im not sure where is the issue, I appreciate your help guys
thank you
