some of the telegraf plugins like inputs.system inputs.cpu are not working, whil inputs.tail works just fine.
has anyone faced this ever?
any solution?
any solution?
input field
“uptime” on measurement “test” is type integer, already exists as type float dropped=54; discarding points
this is the reason.
this was working fine 10 minutes ago. what might have changed the data type all of a sudden?
Hi @neo1702,
It looks like you might be writing values to the same field names in one measurement which have different types. In this case uptime (int) is trying to write values to uptime (float). So you have two options:
there was no change in the server in any manner… how does this change got triggered? is there any way to find out?
@neo1702 could you write some of the data to a file using the file output plugin: telegraf/plugins/outputs/file at master · influxdata/telegraf · GitHub
I can check if there is still a present clash or this is a historical data issue.
