I’m currently using Telegraf v1.23.4. I’m configuring the gNMI plugin to connect to an optical device. The connection is successfully made and I’m subscribing to the /slots
path. It seems like the size of the data being received is beyond what is allowed. I’m seeing the below error message:
2023-01-04T20:16:43Z E! [inputs.gnmi] Error in plugin: aborted gNMI subscription: rpc error: code = ResourceExhausted desc = grpc: received message larger than max (8166999 vs. 4194304)
2023-01-04T20:17:29Z E! [inputs.gnmi] Error in plugin: aborted gNMI subscription: rpc error: code = ResourceExhausted desc = grpc: received message larger than max (8167006 vs. 4194304)
2023-01-04T20:18:13Z E! [inputs.gnmi] Error in plugin: aborted gNMI subscription: rpc error: code = ResourceExhausted desc = grpc: received message larger than max (8166989 vs. 4194304)
2023-01-04T20:18:58Z E! [inputs.gnmi] Error in plugin: aborted gNMI subscription: rpc error: code = ResourceExhausted desc = grpc: received message larger than max (8167002 vs. 4194304)
Also, tried connecting to the /slots[name=1]
path to pull data from slot 1. This reduced the message size but it was still greater than allowed.
2023-01-04T20:28:22Z E! [inputs.gnmi] Error in plugin: aborted gNMI subscription: rpc error: code = ResourceExhausted desc = grpc: received message larger than max (4338740 vs. 4194304)
Is there a way to increase the allowed size of the message?
Thank you.
