Faced the same challenge.
We have created tls certificate and added the same in conf file. It worked.
Hello @DeepikaSivalingam,
Can you please share your telegraf config?
Hi anaisdg,
Im facing same issue could you please help me?
[[inputs.gnmi]]
addresses [“199.100.11.1:57400”]
username “admin”
password “admin”
encoding “json ietf”
insecure_skip verify true
redial “605”
[[inputs.gomi.subscription]]
name “hostname”
origin “openconfig”
path=“/system/name/host-name”
subscription mode “sample”
sample interval “605”
[[outputs.influxdb]]
urls[“http://localhost:8428”]
database “telegraf”
retention policy -
write_consistency = “any”
timeout=“605”
[agent]
interval “105”
round interval = true
metric_batch_size - 1000
metric buffer limit = 10000
collection jitter = “0s”
flush interval - “105”
flush jitter= “05”
precision=" "
debug= true
logtarget =“file”
logfile = “/var/log/telegraf/telegraf.log”
logfile rotation max size = “10MB”
logfile rotation max archives = 5
quiet = false
logfile_rotation_max_size = “10MB”
logfile_rotation_max_archives = 5
Apr 28 10:17:46 10.177.166.241 telegraf [2922611]: 2025-04-28T10:17:46Z E! [inputs.gnmi] Error in plugin: failed to setup subscription: rpc error:
connection closed before server preface received
Hello @theja,
I’m not sure.
Can you try the following trouble shooting ideas?
The plugin documentation mentions that tls handshake failures can occur due to insecure tls configurations in the GNMI server. Maybe adjust tls_min_version or tls_cipher_suites telegraf/plugins/inputs/gnmi/README.md at master · influxdata/telegraf · GitHub.
Use debug = true to check logs and share them.
This could help too? Or this user might?
Otherwise @skartikey might know something I don’t ![]()
Hello @annaidg ,
Im using Telegraf 1.21.4+dsl-0ubuntu2 version cannot able to use the tls_min and tls_cipher
The logs for current version is
25-04-29T07:20:392 E! [inputs.gnmi] Error in plugin: failed to setup subscription: rpc error: code Unavailable desc connection closed before server preface temelved
25-04-29T07:20:492 D! [outputs.influxdb] Buffer fullness: 0/10000 metrics
25-04-29T07:20:592 D! [outputs.influxdb] Buffer fullness: 0/10000 metrica
25-04-29T07:21:09Z D! [outputs.influxdb) Buffer fullness: 0/10000 metrica
25-04-29T07:21:192 D! [outputs.influxdb] Buffer fullness: 0/10000 metrics
[C^[[C^[[C^ [[C2025-04-29T07:21:29Z D! [outputs.influxdb] Buffer fullness: 0/10000 metrics
25-04-29T07:21:392 D! [outputs.influxdb] Buffer fullness: 0/10000 metrics
25-04-29T07:21:492 D! [outputs.influxdb] Buffer fullness: 0/10000 metrics
25-04-29T07:21:59Z D! [outputs.influxdb] Buffer fullness: 0/10000 metrics
25-04-29T07:22:09Z D! [outputs.influxdb] Buffer fullness: 0/10000 metrics
25-04-29T07:22:19Z D! [outputs.influxdb] Buffer fullness: 0/10000 metrics
25-04-29T07:22:19Z E! [inputs.gnmi] Error in plugin: failed to setup subscription: rpc error: code Unavailable desc connection closed before server preface received
Could u please help???
@skartikey could u please help me on this???
@oldguardmd1 ?? U have any idea on this??
@DeepikaSivalingam and @theja Welcome to influxdata community!
I see you’re facing a gNMI connection error: “failed to setup subscription: rpc error: code Unavailable desc = connection closed before server preface received”
This error typically occurs when there’s a connection issue between Telegraf and the gNMI server. Here are several things to check and try:
# Test if you can reach the gNMI server
telnet 199.100.11.1 57400
# Or use nc
nc -v 199.100.11.1 57400
insecure_skip_verify = true, make sure you’ve added an underscore between the words:[[inputs.gnmi]]
addresses = ["199.100.11.1:57400"]
username = "admin"
password = "admin"
encoding = "json_ietf"
redial = "605"
[[inputs.gnmi]]
username = "admin"
password = "admin"
redial = "60s"
[[inputs.gnmi.subscription]]
name = "hostname"
origin = "openconfig"
path = "/system/state/hostname"
subscription_mode = "sample"
sample_interval = "60s"
urls = ["http://localhost:8428"]
database = "telegraf"
timeout = "60s"
[agent]
interval = "10s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 10000
collection_jitter = "0s"
flush_interval = "10s"
flush_jitter = "0s"
precision = ""
debug = true
logtarget = "file"
logfile = "/var/log/telegraf/telegraf.log"
logfile_rotation_max_size = "10MB"
quiet = false
tls_min and tls_cipher):[[inputs.gnmi]]
# ... existing configuration ...
# Try adding these for TLS compatibility
tls_ca = "/path/to/ca.crt" # If you have a CA certificate
tls_cert = "/path/to/client.crt" # If you need client certificate
tls_key = "/path/to/client.key" # If you need client key
# Enable debug mode to see more detailed logs
journalctl -u telegraf -f
# Test connectivity with openssl
openssl s_client -connect 199.100.11.1:57400 -showcerts
# Check Telegraf version
telegraf --version
[[inputs.gnmi]]
username = "admin"
password = "admin"
redial = "60s"
mode = "sample"
interval = "60s"
If none of these solutions work, could you provide:
telegraf --test --config /path/to/your/config?This will help me provide more specific guidance for your situation.
