So… I am trying to specify Advanced TLS configuration for Cisco GNMI (telegraf 1.14.5) input plugin, as stated in: telegraf/docs/TLS.md at v1.14.5 · influxdata/telegraf · GitHub
Can anyone advise if advanced TLS configuration is supported by this plugin?
I am receiving the error below:
[telegraf] Error running agent: Error parsing /etc/telegraf/telegraf.t2/inputs.cisco_gnmi.conf, line 25: field corresponding to `tls_cipher_suites’ is not defined in cisco_telemetry_gnmi.CiscoTelemetryGNMI
Here is my plugin configuration:
[[inputs.cisco_telemetry_gnmi]]
addresses = [“x.x.x.x:x”]
username = “grpc”
password = “”
encoding = “json”
redial = “10s”
enable_tls = truetls_ca = “/certs/CAcert_l1.pem”
tls_cert = “/certs/cert_l1.pem”
tls_key = “/certs/servkey_l1.pem”tls_cipher_suites = [“TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA”,
“TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA”]
tls_min_version = “TLS12”
