When subscribing to gnmi data on a Cisco NCS540, I get good data back from gnmic, but I get no data in influxdb from telegraf using the same method.
My subscription for gnmi looks like this:
[[inputs.gnmi.subscription]]
name = "StatsQosIn"
origin = "Cisco-IOS-XR-qos-ma-oper"
path = "qos/interface-table/interface/input/service-policy-names/service-policy-instance/statistics/class-stats/general-stats"
subscription_mode = "sample"
sample_interval = "10s"
I can get it to ingest into grafana using this:
name = "StatsQosIn"
path = "qos/interface-table/interface/input/service-policy-names/service-policy-instance/statistics"
When I query the intended data at a higher level it populates what I need, but also gives way more data than I need and it makes it much harder to display in grafana.
The gnmic command seems to have no problem querying the data at the level required producing the following output
"source": "10.82.6.84",
"timestamp": 1733152453707271490,
"time": "2024-12-02T10:14:13.70727149-05:00",
"updates": [
"Path": "Cisco-IOS-XR-qos-ma-oper:qos/interface-table/interface[interface-name=TenGigE0/0/0/14]/input/service-policy-names/service-policy-instance[service-policy-name=TEST_POLICIES]/statistics/class-stats/general-stats",
"values": {
"qos/interface-table/interface/input/service-policy-names/service-policy-instance/statistics/class-stats/general-stats": {
"match-data-rate": 0,
"pre-policy-matched-bytes": "0",
"pre-policy-matched-packets": "0",
"total-drop-bytes": "0",
"total-drop-packets": "0",
"total-drop-rate": 0,
"total-transmit-rate": 0,
"transmit-bytes": "0",
"transmit-packets": "0"
"values": {
"values": {
"Path": "Cisco-IOS-XR-qos-ma-oper:qos/interface-table/interface[interface-name=TenGigE0/0/0/17]/input/service-policy-names/service-policy-instance[service-policy-name=TEST_POLICIES]/statistics/class-stats/general-stats",
"values": {
"values": {
"values": {
"match-data-rate": 9833145,
"pre-policy-matched-bytes": "6610480868259",
"pre-policy-matched-packets": "4479660320",
"total-transmit-rate": 9833145,
"transmit-bytes": "6610480868259",
"transmit-packets": "4479660320"
"Path": "Cisco-IOS-XR-qos-ma-oper:qos/interface-table/interface[interface-name=TenGigE0/0/0/16]/input/service-policy-names/service-policy-instance[service-policy-name=TEST_POLICIES]/statistics/class-stats/general-stats",
"values": {
"values": {
"values": {
"match-data-rate": 9840698,
"pre-policy-matched-bytes": "6648379816724",
"pre-policy-matched-packets": "4458172128",
"total-transmit-rate": 9840698,
"transmit-bytes": "6648379816724",
"transmit-packets": "4458172128"
"Path": "Cisco-IOS-XR-qos-ma-oper:qos/interface-table/interface[interface-name=TenGigE0/0/0/15]/input/service-policy-names/service-policy-instance[service-policy-name=TEST_POLICIES]/statistics/class-stats/general-stats",
"values": {
"values": {
"values": {
I am expecting this data from the yang model:
module: Cisco-IOS-XR-qos-ma-oper
+--ro qos
+--ro interface-table
+--ro interface* [interface-name]
+--ro input
+--ro service-policy-names
+--ro service-policy-instance* [service-policy-name]
+--ro statistics
+--ro class-stats* []
+--ro general-stats
+--ro transmit-packets? uint64
+--ro transmit-bytes? uint64
+--ro total-drop-packets? uint64
+--ro total-drop-bytes? uint64
+--ro total-drop-rate? uint32
+--ro match-data-rate? uint32
+--ro total-transmit-rate? uint32
+--ro pre-policy-matched-packets? uint64
+--ro pre-policy-matched-bytes? uint64
Any ideas on how I can get telegraf to ingest this data at the more granular level?
Telegraf Version: 1.28.5
