Telegraf and Influx
Hi, what should I do to collect metrics from different windows servers to my local machine and visualize that telemetry data in Grafana
for instance I am using Telegraf and InfluxDB
and I have more than one windows servers.
Hello @Alpheus,
Thanks for your question.
You can either run it in containers or install the binary.
Here you can find a tutorial for installing influxdb:
The following link has the appropriate telegraf config example:
So do I have to install InfluxDB and Telegraf on every server to collect telemetry data
and visualize it on my machine ?
You should have a telegraf agent running anywhere you want to collect data from, then you can send that data to one InfluxDB instance if you want.
thanks , that is very helpful
to ask again is it possible to send metrics from Telegraf to hosted Graphite suppose my graphite is hosted on : http://metric.graphite.com
if so can you please guide me with some steps.
