I have a series of daily backups that I would like to load into on InfluxDB instance.
I used Influx Version 1.7.4 to archive the data.
My restore node uses Version 1.7.6
I can restore the first day without issue, since the database does not exist in my restore node.
$ influxd restore -portable -db telegraf /tmp/influx-archives/2019-05-19
2019/06/05 17:46:21 Restoring shard 63 live from backup 20190520T010302Z.s63.tar.gz
2019/06/05 17:46:21 Restoring shard 14 live from backup 20190520T010302Z.s14.tar.gz
2019/06/05 17:46:21 Restoring shard 54 live from backup 20190520T010302Z.s54.tar.gz
2019/06/05 17:46:21 Restoring shard 81 live from backup 20190520T010302Z.s81.tar.gz
2019/06/05 17:46:21 Restoring shard 26 live from backup 20190520T010302Z.s26.tar.gz
2019/06/05 17:46:21 Restoring shard 35 live from backup 20190520T010302Z.s35.tar.gz
2019/06/05 17:46:21 Restoring shard 2 live from backup 20190520T010302Z.s2.tar.gz
2019/06/05 17:46:21 Restoring shard 72 live from backup 20190520T010302Z.s72.tar.gz
2019/06/05 17:46:23 Restoring shard 6 live from backup 20190520T010302Z.s6.tar.gz
2019/06/05 17:46:23 Restoring shard 45 live from backup 20190520T010302Z.s45.tar.gz
The database exists and has data.
$ influx
Connected to http://localhost:8086 version 1.7.6
InfluxDB shell version: 1.7.6
Enter an InfluxQL query
> USE telegraf
Using database telegraf
> SELECT count(usage_guest) FROM cpu
time count
0 157860
I then restore the next day of data into telegraf_bak:
$ influxd restore -portable -db telegraf -newdb telegraf_bak /tmp/influx-archives/2019-05-20
2019/06/05 17:51:10 Restoring shard 35 live from backup 20190521T010302Z.s35.tar.gz
2019/06/05 17:51:10 Restoring shard 2 live from backup 20190521T010302Z.s2.tar.gz
2019/06/05 17:51:10 Restoring shard 26 live from backup 20190521T010302Z.s26.tar.gz
2019/06/05 17:51:10 Restoring shard 63 live from backup 20190521T010302Z.s63.tar.gz
2019/06/05 17:51:10 Restoring shard 6 live from backup 20190521T010302Z.s6.tar.gz
2019/06/05 17:51:10 Restoring shard 14 live from backup 20190521T010302Z.s14.tar.gz
2019/06/05 17:51:10 Restoring shard 45 live from backup 20190521T010302Z.s45.tar.gz
2019/06/05 17:51:10 Restoring shard 81 live from backup 20190521T010302Z.s81.tar.gz
2019/06/05 17:51:12 Restoring shard 54 live from backup 20190521T010302Z.s54.tar.gz
2019/06/05 17:51:12 Restoring shard 72 live from backup 20190521T010302Z.s72.tar.gz
The new telegraf_bak exists and includes data.
$ influx
> USE telegraf_bak
Using database telegraf_bak
time count
0 159138
I then copy over the data following the documented sideload procedure.
> [centos@ip-172-31-90-245 ~]$ influx
> USE telegraf_bak
> SELECT * INTO telegraf..:MEASUREMENT FROM /.*/ GROUP BY *
ERR: no data received
Any idea why I get ERR: no data received?
