I am running influxdb 1.2.2.
> ./influx
> Connected to http://localhost:8086 version 1.2.2
> InfluxDB shell version: 1.2.2
> > show databases;
> name
> _internal
> application
> system
> events
I did ./influxd backup -database events /opt/data but it backups only metastore. How do i backup all databases and restore it to 1.7.2. Am i doing it correctly?
Please suggest.
Best Regards,
Kaushal
katy
January 8, 2019, 11:13pm
2
You should be able to backup everything with the influxd backup command :
influxd backup -portable <path-to-backup> should backup everything.
Hi Katy,
I am facing the below issue. Please suggest further. How do i restore the backup to Influxdb 1.7.2
[root@bin]# ll
total 53920
-rwxr-xr-x. 1 root root 7727978 Aug 15 2017 influx
-rwxr-xr-x. 1 root root 17425099 Aug 15 2017 influxd
-rwxr-xr-x. 1 root root 9117049 Aug 15 2017 influx_inspect
-rwxr-xr-x. 1 root root 8066872 Aug 15 2017 influx_stress
-rwxr-xr-x. 1 root root 12868847 Aug 15 2017 influx_tsm
[root@bin]# ps aux | grep influx
root 22516 0.0 0.0 112708 980 pts/0 S+ 02:31 0:00 grep --color=auto influx
[root@bin]# **influxd backup -portable /opt/influxdbbackup**
2019/01/09 02:31:11 backing up metastore to /opt/influxdbbackup/meta.00
2019/01/09 02:31:11 Download shard 0 failed dial tcp [::1]:8088: connect: connection refused. Waiting 2s and retrying (0)...
2019/01/09 02:31:13 Download shard 0 failed dial tcp [::1]:8088: connect: connection refused. Waiting 2s and retrying (1)...
2019/01/09 02:31:15 Download shard 0 failed dial tcp [::1]:8088: connect: connection refused. Waiting 2s and retrying (2)...
2019/01/09 02:31:17 Download shard 0 failed dial tcp [::1]:8088: connect: connection refused. Waiting 2s and retrying (3)...
2019/01/09 02:31:19 Download shard 0 failed dial tcp [::1]:8088: connect: connection refused. Waiting 2s and retrying (4)...
2019/01/09 02:31:21 Download shard 0 failed dial tcp [::1]:8088: connect: connection refused. Waiting 2s and retrying (5)...
2019/01/09 02:31:23 Download shard 0 failed dial tcp [::1]:8088: connect: connection refused. Waiting 3.01s and retrying (6)...
Thanks in Advance.
Best Regards,
katy
January 9, 2019, 5:10pm
4
This looks like the issue reported here .
Can you upgrade the 1.2.2 to a newer version?
