Hi to all,
I’m new to InfluxDB and I’m not able to monitor Proxmox 7. I have installed Telegraf on Proxmox with the following conf:
[agent]
interval = "10s"
## Rounds collection interval to 'interval'
round_interval = true
## Telegraf will send metrics to outputs in batches of at most
## metric_batch_size metrics.
## This controls the size of writes that Telegraf sends to output plugins.
metric_batch_size = 1000
## For failed writes, telegraf will cache metric_buffer_limit metrics for each
## output, and will flush this buffer on a successful write. Oldest metrics
## are dropped first when this buffer fills.
## This buffer only fills when writes fail to output plugin(s).
metric_buffer_limit = 10000
collection_jitter = "0s"
## Default flushing interval for all outputs. Maximum flush_interval will be
## flush_interval + flush_jitter
flush_interval = "10s"
## Jitter the flush interval by a random amount. This is primarily to avoid
## large write spikes for users running a large number of telegraf instances.
## ie, a jitter of 5s and interval 10s means flushes will happen every 10-15s
flush_jitter = "0s"
## By default or when set to "0s", precision will be set to the same
## timestamp order as the collection interval, with the maximum being 1s.
## ie, when interval = "10s", precision will be "1s"
## when interval = "250ms", precision will be "1ms"
## Precision will NOT be used for service inputs. It is up to each individual
## service input to set the timestamp at the appropriate precision.
## Valid time units are "ns", "us" (or "µs"), "ms", "s".
precision = ""
## Logging configuration:
## Run telegraf with debug log messages.
debug = false
## Run telegraf in quiet mode (error log messages only).
quiet = false
## Specify the log file name. The empty string means to log to stderr.
logfile = ""
## Override default hostname, if empty use os.Hostname()
hostname = ""
omit_hostname = false
[[outputs.influxdb_v2]]
## urls exp: http://127.0.0.1:8086
urls = ["https://my_influxdb_url:8086"]
## Token for authentication.
token = "$INFLUX_TOKEN"
organization = "Proxmox Servers"
bucket = "Proxmox Infra"
insecure_skip_verify = true
[[inputs.proxmox]]
## API connection configuration. The API token was introduced in Proxmox v6.2. Required permissions for user and token: PVEAuditor role on /.
base_url = "https://prox-monitor1.proximacomputing.it:8006/api2/json"
# api_token = "USER@REALM!TOKENID=UUID"
api_token = "Monitor@pam!monitor=aa4gcfc7-810y-4dc3-af91-133fe6b60423"
## Node name, defaults to OS hostname
# node_name = ""
## Optional TLS Config
# tls_ca = "/etc/telegraf/ca.pem"
# tls_cert = "/etc/telegraf/cert.pem"
# tls_key = "/etc/telegraf/key.pem"
## Use TLS but skip chain & host verification
#insecure_skip_verify = false
# HTTP response timeout (default: 5s)
response_timeout = "5s"
In InfluxDB I have configured an Organization “Proxmox Servers” and a Bucket “Proxmox Infra”. I have also, in Proxmox 7.0.11 Server, correctly export the INFLUX_TOKEN.
Now in Proxmox Server syslog I have the following error:
E! [inputs.proxmox] Error getting VM stats: %vjson: cannot unmarshal number into Go struct field VMStat.data.vmid of type string
And nothing is sent to InfluxDB server.
In Proxmox I have created a user “Monitor” and an API token with:
- Permission “PVEAuditor”
- Path: /
Could you help me, please?
Thank you
