Collecting metrics for 0 objects
Hi
i try to use influxdb2 + Telegraf to collect metics from vSphere.
I use the following Telegraf config
[agent]
  interval = "10s"
  ## Rounds collection interval to 'interval'
  round_interval = true
  ## Telegraf will send metrics to outputs in batches of at most
  ## metric_batch_size metrics.
  ## This controls the size of writes that Telegraf sends to output plugins.
  metric_batch_size = 1000
  ## Maximum number of unwritten metrics per output.  Increasing this value
  ## allows for longer periods of output downtime without dropping metrics at the
  ## cost of higher maximum memory usage.
  metric_buffer_limit = 10000
  collection_jitter = "0s"
  ## Default flushing interval for all outputs. Maximum flush_interval will be
  ## flush_interval + flush_jitter
  flush_interval = "10s"
  ## Jitter the flush interval by a random amount. This is primarily to avoid
  ## large write spikes for users running a large number of telegraf instances.
  ## ie, a jitter of 5s and interval 10s means flushes will happen every 10-15s
  flush_jitter = "0s"
  ## By default or when set to "0s", precision will be set to the same
  ## timestamp order as the collection interval, with the maximum being 1s.
  ##   ie, when interval = "10s", precision will be "1s"
  ##       when interval = "250ms", precision will be "1ms"
  ## Precision will NOT be used for service inputs. It is up to each individual
  ## service input to set the timestamp at the appropriate precision.
  ## Valid time units are "ns", "us" (or "µs"), "ms", "s".
  precision = ""
  ## Log at debug level.
   debug = true
  ## Log only error level messages.
  # quiet = false
  ## Log target controls the destination for logs and can be one of "file",
  ## "stderr" or, on Windows, "eventlog".  When set to "file", the output file
  ## is determined by the "logfile" setting.
  # logtarget = "file"
  ## Name of the file to be logged to when using the "file" logtarget.  If set to
  ## the empty string then logs are written to stderr.
  # logfile = ""
  ## The logfile will be rotated after the time interval specified.  When set
  ## to 0 no time based rotation is performed.  Logs are rotated only when
  ## written to, if there is no log activity rotation may be delayed.
  # logfile_rotation_interval = "0d"
  ## The logfile will be rotated when it becomes larger than the specified
  ## size.  When set to 0 no size based rotation is performed.
  # logfile_rotation_max_size = "0MB"
  ## Maximum number of rotated archives to keep, any older logs are deleted.
  ## If set to -1, no archives are removed.
  # logfile_rotation_max_archives = 5
  ## Pick a timezone to use when logging or type 'local' for local time.
  ## Example: America/Chicago
  # log_with_timezone = ""
  ## Override default hostname, if empty use os.Hostname()
  hostname = ""
  omit_hostname = false
[[outputs.influxdb_v2]]
  ##   ex: urls = ["https://us-west-2-1.aws.cloud2.influxdata.com"]
  urls = ["http://ip:8086"]
  ## Token for authentication.
  token = "$INFLUX_TOKEN"
  organization = "org"
  bucket = "bucket"
  ## The value of this tag will be used to determine the bucket.  If this
  ## tag is not set the 'bucket' option is used as the default.
  # bucket_tag = ""
  ## If true, the bucket tag will not be added to the metric.
  # exclude_bucket_tag = false
  ## Timeout for HTTP messages.
  # timeout = "5s"
  ## Additional HTTP headers
  # http_headers = {"X-Special-Header" = "Special-Value"}
  ## HTTP Proxy override, if unset values the standard proxy environment
  ## variables are consulted to determine which proxy, if any, should be used.
  # http_proxy = "http://corporate.proxy:3128"
  ## HTTP User-Agent
  # user_agent = "telegraf"
  ## Content-Encoding for write request body, can be set to "gzip" to
  ## compress body or "identity" to apply no encoding.
  # content_encoding = "gzip"
  ## Enable or disable uint support for writing uints influxdb 2.0.
  # influx_uint_support = false
  ## Optional TLS Config for use on HTTP connections.
  # tls_ca = "/etc/telegraf/ca.pem"
  # tls_cert = "/etc/telegraf/cert.pem"
  # tls_key = "/etc/telegraf/key.pem"
  ## Use TLS but skip chain & host verification
   insecure_skip_verify = false
## Realtime instance
[[inputs.vsphere]]
## List of vCenter URLs to be monitored. These three lines must be uncommented
## and edited for the plugin to work.
interval = "60s"
  vcenters = [ "https://vcenter.test/sdk" ]
  username = "test@vmware.local"
  password = "secret"
vm_metric_include = []
host_metric_include = []
cluster_metric_include = []
datastore_metric_exclude = ["*"]
max_query_metrics = 256
timeout = "60s"
insecure_skip_verify = true
## Historical instance
[[inputs.vsphere]]
interval = "300s"
  password = "secret"
  datastore_metric_include = [ "disk.capacity.latest", "disk.used.latest", "disk.provisioned.latest" ]
  force_discover_on_init = true
  host_metric_exclude = ["*"] # Exclude realtime metrics
  vm_metric_exclude = ["*"] # Exclude realtime metrics
  collect_concurrency = 3
But i get back that there is 0 metrics to collect:
2024-04-26T13:37:22Z I! Starting Telegraf 1.30.2 brought to you by InfluxData the makers of InfluxDB
2024-04-26T13:37:22Z I! Available plugins: 233 inputs, 9 aggregators, 31 processors, 24 parsers, 60 outputs, 6 secret-stores
2024-04-26T13:37:22Z I! Loaded inputs: vsphere
2024-04-26T13:37:22Z I! Loaded aggregators:
2024-04-26T13:37:22Z I! Loaded processors:
2024-04-26T13:37:22Z I! Loaded secretstores:
2024-04-26T13:37:22Z I! Loaded outputs: influxdb_v2
2024-04-26T13:37:22Z I! Tags enabled: host=sys-influx01
2024-04-26T13:37:22Z W! Deprecated inputs: 0 and 1 options
2024-04-26T13:37:22Z I! [agent] Config: Interval:10s, Quiet:false, Hostname:"sys-influx01", Flush Interval:10s
2024-04-26T13:37:22Z D! [agent] Initializing plugins
2024-04-26T13:37:22Z D! [agent] Connecting outputs
2024-04-26T13:37:22Z D! [agent] Attempting connection to [outputs.influxdb_v2]
2024-04-26T13:37:22Z D! [agent] Successfully connected to outputs.influxdb_v2
2024-04-26T13:37:22Z D! [agent] Starting service inputs
2024-04-26T13:37:22Z I! [inputs.vsphere] Starting plugin
2024-04-26T13:37:22Z D! [inputs.vsphere] Creating client: vcenter.test
2024-04-26T13:37:22Z D! [inputs.vsphere] vCenter maxQueryMetrics is defined: 256
2024-04-26T13:37:22Z D! [inputs.vsphere] vCenter says max_query_metrics should be 256
2024-04-26T13:37:22Z D! [inputs.vsphere] Running initial discovery
2024-04-26T13:37:23Z D! [inputs.vsphere] Discover new objects for vcenter.test
2024-04-26T13:37:23Z D! [inputs.vsphere] Discovering resources for host
2024-04-26T13:37:23Z D! [inputs.vsphere] Find(HostSystem, /*/host/**) returned 0 objects
2024-04-26T13:37:23Z D! [inputs.vsphere] Discovering resources for vm
2024-04-26T13:37:23Z D! [inputs.vsphere] Find(VirtualMachine, /*/vm/**) returned 0 objects
2024-04-26T13:37:23Z D! [inputs.vsphere] Find(ResourcePool, /*/host/**) returned 0 objects
2024-04-26T13:37:23Z D! [inputs.vsphere] Discovering resources for datastore
2024-04-26T13:37:23Z D! [inputs.vsphere] Find(Datastore, /*/datastore/**) returned 0 objects
2024-04-26T13:37:23Z D! [inputs.vsphere] Discovering resources for vsan
2024-04-26T13:37:23Z D! [inputs.vsphere] Discovering resources for datacenter
2024-04-26T13:37:23Z D! [inputs.vsphere] Find(Datacenter, /*) returned 0 objects
2024-04-26T13:37:23Z D! [inputs.vsphere] Discovering resources for cluster
2024-04-26T13:37:23Z D! [inputs.vsphere] Find(ClusterComputeResource, /*/host/**) returned 0 objects
2024-04-26T13:37:23Z D! [inputs.vsphere] Discovering resources for resourcepool
2024-04-26T13:37:33Z D! [outputs.influxdb_v2] Buffer fullness: 0 / 10000 metrics
Is there anything i miss in the config file, for not collecting anything?
The first thing that comes to mind is I would verify the user you are using has sufficient permissions.
Your config shows 2 vsphere plugins, but your log only shows one running as well.
Both is started. My bad, i insterted too short log.
Here is a longer version:
2024-04-30T08:42:39Z W! DeprecationWarning: Option "force_discover_on_init" of plugin "inputs.vsphere" deprecated since version 1.14.0 and will be removed in 2.0.0: option is ignored
2024-04-30T08:42:39Z I! Starting Telegraf 1.30.2 brought to you by InfluxData the makers of InfluxDB
2024-04-30T08:42:39Z I! Available plugins: 233 inputs, 9 aggregators, 31 processors, 24 parsers, 60 outputs, 6 secret-stores
2024-04-30T08:42:39Z I! Loaded inputs: vsphere (2x)
2024-04-30T08:42:39Z I! Loaded aggregators:
2024-04-30T08:42:39Z I! Loaded processors:
2024-04-30T08:42:39Z I! Loaded secretstores:
2024-04-30T08:42:39Z I! Loaded outputs: influxdb_v2
2024-04-30T08:42:39Z I! Tags enabled: host=sys-influx01
2024-04-30T08:42:39Z W! Deprecated inputs: 0 and 2 options
2024-04-30T08:42:39Z I! [agent] Config: Interval:10s, Quiet:false, Hostname:"sys-influx01", Flush Interval:10s
2024-04-30T08:42:39Z D! [agent] Initializing plugins
2024-04-30T08:42:39Z D! [agent] Connecting outputs
2024-04-30T08:42:39Z D! [agent] Attempting connection to [outputs.influxdb_v2]
2024-04-30T08:42:39Z D! [agent] Successfully connected to outputs.influxdb_v2
2024-04-30T08:42:39Z D! [agent] Starting service inputs
2024-04-30T08:42:39Z I! [inputs.vsphere] Starting plugin
2024-04-30T08:42:39Z D! [inputs.vsphere] Creating client: vcenter.test
2024-04-30T08:42:39Z D! [inputs.vsphere] vCenter maxQueryMetrics is defined: 256
2024-04-30T08:42:39Z D! [inputs.vsphere] vCenter says max_query_metrics should be 256
2024-04-30T08:42:39Z D! [inputs.vsphere] Running initial discovery
2024-04-30T08:42:39Z D! [inputs.vsphere] Discover new objects for vcenter.test
2024-04-30T08:42:39Z D! [inputs.vsphere] Discovering resources for vsan
2024-04-30T08:42:39Z D! [inputs.vsphere] Discovering resources for datacenter
2024-04-30T08:42:39Z D! [inputs.vsphere] Find(Datacenter, /*) returned 0 objects
2024-04-30T08:42:39Z D! [inputs.vsphere] Discovering resources for cluster
2024-04-30T08:42:39Z D! [inputs.vsphere] Find(ClusterComputeResource, /*/host/**) returned 0 objects
2024-04-30T08:42:39Z D! [inputs.vsphere] Discovering resources for resourcepool
2024-04-30T08:42:39Z D! [inputs.vsphere] Find(ResourcePool, /*/host/**) returned 0 objects
2024-04-30T08:42:39Z D! [inputs.vsphere] Discovering resources for host
2024-04-30T08:42:39Z D! [inputs.vsphere] Find(HostSystem, /*/host/**) returned 0 objects
2024-04-30T08:42:39Z D! [inputs.vsphere] Discovering resources for vm
2024-04-30T08:42:39Z D! [inputs.vsphere] Find(VirtualMachine, /*/vm/**) returned 0 objects
2024-04-30T08:42:39Z D! [inputs.vsphere] Discovering resources for datastore
2024-04-30T08:42:39Z D! [inputs.vsphere] Find(Datastore, /*/datastore/**) returned 0 objects
2024-04-30T08:42:40Z D! [inputs.vsphere] Discover new objects for vcenter.test
2024-04-30T08:42:40Z D! [inputs.vsphere] Discovering resources for datacenter
2024-04-30T08:42:40Z D! [inputs.vsphere] Find(Datacenter, /*) returned 0 objects
2024-04-30T08:42:40Z D! [inputs.vsphere] Discovering resources for cluster
2024-04-30T08:42:40Z D! [inputs.vsphere] Find(ClusterComputeResource, /*/host/**) returned 0 objects
2024-04-30T08:42:40Z D! [inputs.vsphere] Discovering resources for resourcepool
2024-04-30T08:42:40Z D! [inputs.vsphere] Find(ResourcePool, /*/host/**) returned 0 objects
2024-04-30T08:42:40Z D! [inputs.vsphere] Discovering resources for host
2024-04-30T08:42:40Z D! [inputs.vsphere] Find(HostSystem, /*/host/**) returned 0 objects
2024-04-30T08:42:40Z D! [inputs.vsphere] Discovering resources for vm
2024-04-30T08:42:40Z D! [inputs.vsphere] Discovering resources for datastore
2024-04-30T08:42:40Z D! [inputs.vsphere] Find(Datastore, /*/datastore/**) returned 0 objects
2024-04-30T08:42:40Z D! [inputs.vsphere] Using fast metric metadata selection for datastore
2024-04-30T08:42:40Z D! [inputs.vsphere] Discovering resources for vsan
2024-04-30T08:42:50Z D! [outputs.influxdb_v2] Buffer fullness: 0 / 10000 metrics
2024-04-30T08:43:00Z D! [outputs.influxdb_v2] Buffer fullness: 0 / 10000 metrics
2024-04-30T08:43:00Z D! [inputs.vsphere] Interval estimated to 1m0s
2024-04-30T08:43:00Z D! [inputs.vsphere] Collecting metrics for 0 objects of type vm for vcenter.test
2024-04-30T08:43:00Z D! [inputs.vsphere] Latest sample for vm set to 0001-01-01 00:00:00 +0000 UTC
2024-04-30T08:43:00Z D! [inputs.vsphere] Collecting metrics for 0 objects of type resourcepool for vcenter.test
2024-04-30T08:43:00Z D! [inputs.vsphere] Latest sample for resourcepool set to 0001-01-01 00:00:00 +0000 UTC
2024-04-30T08:43:00Z D! [inputs.vsphere] Collecting metrics for 0 objects of type datacenter for vcenter.test
2024-04-30T08:43:00Z D! [inputs.vsphere] Latest sample for datacenter set to 0001-01-01 00:00:00 +0000 UTC
2024-04-30T08:43:00Z D! [inputs.vsphere] Collecting metrics for 0 objects of type host for vcenter.test
2024-04-30T08:43:00Z D! [inputs.vsphere] Latest sample for host set to 0001-01-01 00:00:00 +0000 UTC
2024-04-30T08:43:00Z D! [inputs.vsphere] Collecting metrics for 0 objects of type cluster for vcenter.si.net
2024-04-30T08:43:00Z D! [inputs.vsphere] Latest sample for cluster set to 0001-01-01 00:00:00 +0000 UTC
2024-04-30T08:43:00Z D! [inputs.vsphere] purged timestamp cache. 0 deleted with 0 remaining
2024-04-30T08:43:10Z D! [outputs.influxdb_v2] Buffer fullness: 0 / 10000 metrics
2024-04-30T08:43:20Z D! [outputs.influxdb_v2] Buffer fullness: 0 / 10000 metrics
2024-04-30T08:43:30Z D! [outputs.influxdb_v2] Buffer fullness: 0 / 10000 metrics
2024-04-30T08:43:40Z D! [outputs.influxdb_v2] Buffer fullness: 0 / 10000 metrics
2024-04-30T08:43:50Z D! [outputs.influxdb_v2] Buffer fullness: 0 / 10000 metrics
^C2024-04-30T08:43:54Z D! [agent] Stopping service inputs
2024-04-30T08:43:54Z I! [inputs.vsphere] Stopping plugin
2024-04-30T08:43:54Z D! [inputs.vsphere] Waiting for endpoint "vcenter.test" to finish
2024-04-30T08:43:54Z D! [inputs.vsphere] Exiting discovery goroutine for vcenter.si.net
2024-04-30T08:43:54Z D! [agent] Input channel closed
2024-04-30T08:43:54Z I! [agent] Hang on, flushing any cached metrics before shutdown
2024-04-30T08:43:54Z D! [outputs.influxdb_v2] Buffer fullness: 0 / 10000 metrics
2024-04-30T08:43:54Z I! [agent] Stopping running outputs
2024-04-30T08:43:54Z D! [agent] Stopped Successfully
if i see journalctl -u telegraf and influxdb there is a lot 401 error.
Apr 30 10:57:02 sys-influx01 systemd[1]: Started Telegraf.
Apr 30 10:57:02 sys-influx01 telegraf[122813]: 2024-04-30T08:57:02Z I! [agent] Config: Interval:10s, Quiet:false, Hostname:"sys-influx01", Flush Interval:10s
Apr 30 10:57:12 sys-influx01 telegraf[122813]: 2024-04-30T08:57:12Z E! [outputs.influxdb_v2] When writing to [http://ip:8086]: failed to write metric to alap (401 Una>
Apr 30 10:57:12 sys-influx01 telegraf[122813]: 2024-04-30T08:57:12Z E! [agent] Error writing to outputs.influxdb_v2: failed to send metrics to any configured server(s)
Apr 30 10:57:22 sys-influx01 telegraf[122813]: 2024-04-30T08:57:22Z E! [outputs.influxdb_v2] When writing to [http://ip:8086]: failed to write metric to alap (401 Una>
Apr 30 10:57:22 sys-influx01 telegraf[122813]: 2024-04-30T08:57:22Z E! [agent] Error writing to outputs.influxdb_v2: failed to send metrics to any configured server(s)
Apr 30 10:56:58 sys-influx01 influxd-systemd-start.sh[122755]: InfluxDB started
Apr 30 10:56:58 sys-influx01 systemd[1]: Started InfluxDB is an open-source, distributed, time series database.
Apr 30 10:57:12 sys-influx01 influxd-systemd-start.sh[122756]: ts=2024-04-30T08:57:12.233410Z lvl=info msg=Unauthorized log_id=0osZOFOl000 error="authorization not found"
Apr 30 10:57:22 sys-influx01 influxd-systemd-start.sh[122756]: ts=2024-04-30T08:57:22.233899Z lvl=info msg=Unauthorized log_id=0osZOFOl000 error="authorization not found"
Apr 30 10:57:32 sys-influx01 influxd-systemd-start.sh[122756]: ts=2024-04-30T08:57:32.234398Z lvl=info msg=Unauthorized log_id=0osZOFOl000 error="authorization not found"
Apr 30 10:57:40 sys-influx01 influxd-systemd-start.sh[122756]: ts=2024-04-30T08:57:40.773072Z lvl=info msg=Unauthorized log_id=0osZOFOl000 error="session not found"
Apr 30 10:57:42 sys-influx01 influxd-systemd-start.sh[122756]: ts=2024-04-30T08:57:42.235878Z lvl=info msg=Unauthorized log_id=0osZOFOl000 error="authorization not found"
Apr 30 10:57:52 sys-influx01 influxd-systemd-start.sh[122756]: ts=2024-04-30T08:57:52.235063Z lvl=info msg=Unauthorized log_id=0osZOFOl000 error="authorization not found"
Apr 30 10:58:02 sys-influx01 influxd-systemd-start.sh[122756]: ts=2024-04-30T08:58:02.235411Z lvl=info msg=Unauthorized log_id=0osZOFOl000 error="authorization not found"
Apr 30 10:58:12 sys-influx01 influxd-systemd-start.sh[122756]: ts=2024-04-30T08:58:12.235842Z lvl=info msg=Unauthorized log_id=0osZOFOl000 error="authorization not found"
Apr 30 10:58:22 sys-influx01 influxd-systemd-start.sh[122756]: ts=2024-04-30T08:58:22.235892Z lvl=info msg=Unauthorized log_id=0osZOFOl000 error="authorization not found"
Apr 30 10:58:32 sys-influx01 influxd-systemd-start.sh[122756]: ts=2024-04-30T08:58:32.236347Z lvl=info msg=Unauthorized log_id=0osZOFOl000 error="authorization not found"
Apr 30 10:58:42 sys-influx01 influxd-systemd-start.sh[122756]: ts=2024-04-30T08:58:42.237406Z lvl=info msg=Unauthorized log_id=0osZOFOl000 error="authorization not found"
Apr 30 10:58:52 sys-influx01 influxd-systemd-start.sh[122756]: ts=2024-04-30T08:58:52.238161Z lvl=info msg=Unauthorized log_id=0osZOFOl000 error="authorization not found"
Apr 30 10:59:02 sys-influx01 influxd-systemd-start.sh[122756]: ts=2024-04-30T08:59:02.239596Z lvl=info msg=Unauthorized log_id=0osZOFOl000 error="authorization not found"
Apr 30 10:59:12 sys-influx01 influxd-systemd-start.sh[122756]: ts=2024-04-30T08:59:12.240303Z lvl=info msg=Unauthorized log_id=0osZOFOl000 error="authorization not found"
Apr 30 10:59:22 sys-influx01 influxd-systemd-start.sh[122756]: ts=2024-04-30T08:59:22.240928Z lvl=info msg=Unauthorized log_id=0osZOFOl000 error="authorization not found"
Apr 30 10:59:32 sys-influx01 influxd-systemd-start.sh[122756]: ts=2024-04-30T08:59:32.241130Z lvl=info msg=Unauthorized log_id=0osZOFOl000 error="authorization not found"
Apr 30 10:59:42 sys-influx01 influxd-systemd-start.sh[122756]: ts=2024-04-30T08:59:42.242378Z lvl=info msg=Unauthorized log_id=0osZOFOl000 error="authorization not found"
Apr 30 10:59:52 sys-influx01 influxd-systemd-start.sh[122756]: ts=2024-04-30T08:59:52.242791Z lvl=info msg=Unauthorized log_id=0osZOFOl000 error="authorization not found"
But i use the right API Token, what i generated for the Telegraf agent on the GUI.
I’m closing the ticket.
After resting the issue for days. Now i see the problem.
In authorization issue was in vSphere.
I leave the comments above. Maybe it will be useful for someone else, if you post an error like this you know where to look for the permission problem.
