I’ve got a csv of 1.7 million records and I want to read it and insert it in a bucket of InfluxDB via Telegraf.
This is my Telegraf configuration:
Configuration for telegraf agent
[agent]
Default data collection interval for all inputs
interval = “30s”
Rounds collection interval to ‘interval’
ie, if interval=“10s” then always collect on :00, :10, :20, etc.
round_interval = true
Telegraf will send metrics to outputs in batches of at most
metric_batch_size metrics.
This controls the size of writes that Telegraf sends to output plugins.
metric_batch_size = 100
Maximum number of unwritten metrics per output. Increasing this value
allows for longer periods of output downtime without dropping metrics at the
cost of higher maximum memory usage.
metric_buffer_limit = 150000
Collection jitter is used to jitter the collection by a random amount.
Each plugin will sleep for a random time within jitter before collecting.
This can be used to avoid many plugins querying things like sysfs at the
same time, which can have a measurable effect on the system.
collection_jitter = “0s”
Default flushing interval for all outputs. Maximum flush_interval will be
flush_interval + flush_jitter
flush_interval = “10s”
Jitter the flush interval by a random amount. This is primarily to avoid
large write spikes for users running a large number of telegraf instances.
ie, a jitter of 5s and interval 10s means flushes will happen every 10-15s
flush_jitter = “0s”
However when I execute Telegraf, these warnings appears:
Some data is well inserted into the bucket but others are discarded.
How do I have to change my buffer configuration to ingest all the data?
