I’m trying to configure stack : InfluxDB V2 + Telegraf V1.17.3
When I try to monitor my MySQL instance I have some probs .
If I configure my /etc/telegraf/telegraf.conf like that :
Configuration for telegraf agent
[agent]
interval = "10s"
## Rounds collection interval to 'interval'
round_interval = true
## Telegraf will send metrics to outputs in batches of at most
## metric_batch_size metrics.
## This controls the size of writes that Telegraf sends to output plugins.
metric_batch_size = 1000
## For failed writes, telegraf will cache metric_buffer_limit metrics for each
## output, and will flush this buffer on a successful write. Oldest metrics
## are dropped first when this buffer fills.
## This buffer only fills when writes fail to output plugin(s).
metric_buffer_limit = 10000
collection_jitter = "0s"
## Default flushing interval for all outputs. Maximum flush_interval will be
## flush_interval + flush_jitter
flush_interval = "10s"
## Jitter the flush interval by a random amount. This is primarily to avoid
## large write spikes for users running a large number of telegraf instances.
## ie, a jitter of 5s and interval 10s means flushes will happen every 10-15s
flush_jitter = "0s"
## By default or when set to "0s", precision will be set to the same
## timestamp order as the collection interval, with the maximum being 1s.
## ie, when interval = "10s", precision will be "1s"
## when interval = "250ms", precision will be "1ms"
## Precision will NOT be used for service inputs. It is up to each individual
## service input to set the timestamp at the appropriate precision.
## Valid time units are "ns", "us" (or "µs"), "ms", "s".
precision = ""
## Logging configuration:
## Run telegraf with debug log messages.
debug = false
## Run telegraf in quiet mode (error log messages only).
quiet = false
## Specify the log file name. The empty string means to log to stderr.
logfile = ""
## Override default hostname, if empty use os.Hostname()
hostname = ""
omit_hostname = false
[[outputs.influxdb_v2]]
## urls exp: http://127.0.0.1:8086
urls = ["http://10.0.0.18:8086"]
## Token for authentication.
token = "$INFLUX_TOKEN"
organization = "MyORG"
bucket = "SRV"
[[inputs.cpu]]
## Whether to report per-cpu stats or not
percpu = true
## Whether to report total system cpu stats or not
totalcpu = true
## If true, collect raw CPU time metrics.
collect_cpu_time = false
## If true, compute and report the sum of all non-idle CPU states.
report_active = false
[[inputs.disk]]
## By default stats will be gathered for all mount points.
## Set mount_points will restrict the stats to only the specified mount points.
# mount_points = ["/"]
## Ignore mount points by filesystem type.
ignore_fs = ["tmpfs", "devtmpfs", "devfs", "overlay", "aufs", "squashfs"]
[[inputs.diskio]]
[[inputs.mem]]
[[inputs.net]]
[[inputs.processes]]
[[inputs.swap]]
[[inputs.system]]
I have this error code :
E! [outputs.influxdb_v2] when writing to [http://10.0.0.18:8086]: failed to write metric (401 Unauthorized): unauthorized: unauthorized access
telegraf[4714]: 2021-02-22T17:47:50Z E! [agent] Error writing to outputs.influxdb_v2: failed to write metric (401 Unauthorized): unauthorized: unauthorized access
I use an all access token.
If I use this command :
telegraf --config http://10.0.24.18:8086/api/v2/telegrafs/071e8f549f353
I can see the output into y influxdb data explorer.
Anyone can explain me the problem ?
