Undefined but requested output: influxdb_v2
Getting below error while running telegraf on host machine [Machine does not have root permission]
2021/07/02 15:33:24 I! Using config file: /users/gen/oneview/.telegraf/telegraf.conf
2021/07/02 15:33:24 E! Error parsing /users/gen/oneview/.telegraf/telegraf.conf, Undefined but requested output: influxdb_v2
------ config file-----
Configuration for sending metrics to InfluxDB
[[outputs.influxdb_v2]]
## ex: urls = [“https://us-west-2-1.aws.cloud2.influxdata.com”]
urls = [“http://****************:8086”]
## Token for authentication.
token = “$INFLUX_TOKEN”
#token = “PZichKfo3wQLo35-K-5UqFlvm3whcnP-uQXM6AnxSZf0XNHOMjVP8fxzNLD2EhaxkBfV0_FJHV4qj6j5Xgx_AA==”
organization = “***”
bucket = “telegraf”
which version of telegraf are you running?
if it’s an old version it might not have outputs.influxdb_v2
otherwise, it can be a
  • a typo (but looks fine to me)
  • you are using a custom build, and that plugin was not included
  • a bug
Got the solution, issue was due to version mix match, i am using latest version and was using config file from old telegraf version.
Thanks a lot for checking my post.
Lesson Learnt - Always have same version on all servers and use same config file.
