Facing issue in running telegraf docker
  • I have a docker container running influxdb (version: v2.7.6).
  • My telegraf.conf looks like this:
[[outputs.influxdb_v2]]
 ## urls exp: http://127.0.0.1:8086
 urls = ["http://localhost:8086"]
 ## Token for authentication.
 token = "$DOCKER_INFLUXDB_INIT_ADMIN_TOKEN"
 organization = "org1"
 bucket = "bucket_test"
  • When I am running my Telegraf docker with the following command:
docker run -d --name=telegraf \
      -v /mytelegrafconfigsdir/telegraf.conf:/var/lib/influxdb \
      --net=influxdb-telegraf-net \
      telegraf
  • it is failing to run and the log is as below:
2024-07-10T07:25:56Z I! Loading config: /etc/telegraf/telegraf.conf
2024-07-10T07:25:56Z E! [telegraf] Error running agent: no outputs found, did you provide a valid config file?
I am unable to understand why is my output isn’t considered from the config file. Pardon me for any blunders but I am just a day old in this. Thanks in advance!
This is not the right path to upload the config to. It should be /etc/telegraf/telegraf.conf
