Hi!
I’m fairly new to influx & telegraf and am trying to get all of this working on windows.
I’ve installed influxdb 2.0.4 on docker and the latest telegraf “seperately” on windows.
Setup
In the meantime I’ve managed to reach the influx UI in my chrome browser.
With this I’ve created a token with read/write permission to a newly created bucket.
For telegraf I’ve edited the config to include the necessary details (through the influx UI with “InfluxDB Output Plugin”). I’ve removed all other inputs and manually added the ‘ping’ config pointing to a local server:
# Telegraf Configuration
# Telegraf is entirely plugin driven. All metrics are gathered from the
# declared inputs, and sent to the declared outputs.
# Plugins must be declared in here to be active.
# To deactivate a plugin, comment out the name and any variables.
# Use 'telegraf -config telegraf.conf -test' to see what metrics a config
# file would generate.
# Environment variables can be used anywhere in this config file, simply surround
# them with ${}. For strings the variable must be within quotes (ie, "${STR_VAR}"),
# for numbers and booleans they should be plain (ie, ${INT_VAR}, ${BOOL_VAR})
# Global tags can be specified here in key="value" format.
[global_tags]
# dc = "us-east-1" # will tag all metrics with dc=us-east-1
# rack = "1a"
## Environment variables can be used as tags, and throughout the config file
# user = "$USER"
[agent]
interval = "10s"
## Rounds collection interval to 'interval'
round_interval = true
## Telegraf will send metrics to outputs in batches of at most
## metric_batch_size metrics.
## This controls the size of writes that Telegraf sends to output plugins.
metric_batch_size = 1000
## Maximum number of unwritten metrics per output. Increasing this value
## allows for longer periods of output downtime without dropping metrics at the
## cost of higher maximum memory usage.
metric_buffer_limit = 10000
collection_jitter = "0s"
## Default flushing interval for all outputs. Maximum flush_interval will be
## flush_interval + flush_jitter
flush_interval = "10s"
## Jitter the flush interval by a random amount. This is primarily to avoid
## large write spikes for users running a large number of telegraf instances.
## ie, a jitter of 5s and interval 10s means flushes will happen every 10-15s
flush_jitter = "0s"
## By default or when set to "0s", precision will be set to the same
## timestamp order as the collection interval, with the maximum being 1s.
## ie, when interval = "10s", precision will be "1s"
## when interval = "250ms", precision will be "1ms"
## Precision will NOT be used for service inputs. It is up to each individual
## service input to set the timestamp at the appropriate precision.
## Valid time units are "ns", "us" (or "µs"), "ms", "s".
precision = ""
## Log at debug level.
debug = true
## Log only error level messages.
quiet = false
## Log target controls the destination for logs and can be one of "file",
## "stderr" or, on Windows, "eventlog". When set to "file", the output file
## is determined by the "logfile" setting.
logtarget = "file"
## Name of the file to be logged to when using the "file" logtarget. If set to
## the empty string then logs are written to stderr.
logfile = "telegrafLogs"
## The logfile will be rotated after the time interval specified. When set
## to 0 no time based rotation is performed. Logs are rotated only when
## written to, if there is no log activity rotation may be delayed.
# logfile_rotation_interval = "0d"
## The logfile will be rotated when it becomes larger than the specified
## size. When set to 0 no size based rotation is performed.
# logfile_rotation_max_size = "0MB"
## Maximum number of rotated archives to keep, any older logs are deleted.
## If set to -1, no archives are removed.
# logfile_rotation_max_archives = 5
## Override default hostname, if empty use os.Hostname()
hostname = ""
omit_hostname = false
# OUTPUT PLUGINS #
# Configuration for sending metrics to InfluxDB
# [[outputs.influxdb]]
## The full HTTP or UDP URL for your InfluxDB instance.
# urls = ["unix:///var/run/influxdb.sock"]
# urls = ["udp://127.0.0.1:8089"]
# urls = ["http://127.0.0.1:8086"]
## The target database for metrics; will be created as needed.
## For UDP url endpoint database needs to be configured on server side.
# database = "telegraf"
## The value of this tag will be used to determine the database. If this
## tag is not set the 'database' option is used as the default.
# database_tag = ""
## If true, the 'database_tag' will not be included in the written metric.
# exclude_database_tag = false
## If true, no CREATE DATABASE queries will be sent. Set to true when using
## Telegraf with a user without permissions to create databases or when the
## database already exists.
# skip_database_creation = false
## Name of existing retention policy to write to. Empty string writes to
## the default retention policy. Only takes effect when using HTTP.
# retention_policy = ""
## The value of this tag will be used to determine the retention policy. If this
## tag is not set the 'retention_policy' option is used as the default.
# retention_policy_tag = ""
## If true, the 'retention_policy_tag' will not be included in the written metric.
# exclude_retention_policy_tag = false
## Write consistency (clusters only), can be: "any", "one", "quorum", "all".
## Only takes effect when using HTTP.
# write_consistency = "any"
## Timeout for HTTP messages.
# timeout = "5s"
## HTTP Basic Auth
# username = "telegraf"
# password = "metricsmetricsmetricsmetrics"
## HTTP User-Agent
# user_agent = "telegraf"
## UDP payload size is the maximum packet size to send.
# udp_payload = "512B"
## Optional TLS Config for use on HTTP connections.
# tls_ca = "/etc/telegraf/ca.pem"
# tls_cert = "/etc/telegraf/cert.pem"
# tls_key = "/etc/telegraf/key.pem"
## Use TLS but skip chain & host verification
## HTTP Proxy override, if unset values the standard proxy environment
## variables are consulted to determine which proxy, if any, should be used.
# http_proxy = "http://corporate.proxy:3128"
## Additional HTTP headers
# http_headers = {"X-Special-Header" = "Special-Value"}
## HTTP Content-Encoding for write request body, can be set to "gzip" to
## compress body or "identity" to apply no encoding.
# content_encoding = "identity"
## When true, Telegraf will output unsigned integers as unsigned values,
## i.e.: "42u". You will need a version of InfluxDB supporting unsigned
## integer values. Enabling this option will result in field type errors if
## existing data has been written.
# influx_uint_support = false
# # Configuration for sending metrics to InfluxDB
[[outputs.influxdb_v2]]
## urls exp: http://127.0.0.1:8086
urls = ["http://localhost:8086"]
## Token for authentication.
token = "$INFLUX_TOKEN"
organization = "My Test Organization"
bucket = "testdb_1"
# ## The value of this tag will be used to determine the bucket. If this
# ## tag is not set the 'bucket' option is used as the default.
# # bucket_tag = ""
# ## If true, the bucket tag will not be added to the metric.
# # exclude_bucket_tag = false
# ## Timeout for HTTP messages.
# # timeout = "5s"
# ## Additional HTTP headers
# # http_headers = {"X-Special-Header" = "Special-Value"}
# ## HTTP Proxy override, if unset values the standard proxy environment
# ## variables are consulted to determine which proxy, if any, should be used.
# # http_proxy = "http://corporate.proxy:3128"
# ## HTTP User-Agent
# # user_agent = "telegraf"
# ## Content-Encoding for write request body, can be set to "gzip" to
# ## compress body or "identity" to apply no encoding.
# # content_encoding = "gzip"
# ## Enable or disable uint support for writing uints influxdb 2.0.
# # influx_uint_support = false
# ## Optional TLS Config for use on HTTP connections.
# # tls_ca = "/etc/telegraf/ca.pem"
# # tls_cert = "/etc/telegraf/cert.pem"
# # tls_key = "/etc/telegraf/key.pem"
# ## Use TLS but skip chain & host verification
# # insecure_skip_verify = false
# INPUT PLUGINS #
[[inputs.ping]]
## Hosts to send ping packets to.
urls = ["10.100.2.36"]
## Method used for sending pings, can be either "exec" or "native". When set
## to "exec" the systems ping command will be executed. When set to "native"
## the plugin will send pings directly.
## While the default is "exec" for backwards compatibility, new deployments
## are encouraged to use the "native" method for improved compatibility and
## performance.
method = "native"
## Number of ping packets to send per interval. Corresponds to the "-c"
## option of the ping command.
count = 2
## Time to wait between sending ping packets in seconds. Operates like the
## "-i" option of the ping command.
ping_interval = 1.0
## If set, the time to wait for a ping response in seconds. Operates like
## the "-W" option of the ping command.
timeout = 3.0
## If set, the total ping deadline, in seconds. Operates like the -w option
## of the ping command.
# deadline = 10
## Interface or source address to send ping from. Operates like the -I or -S
# interface = ""
## Percentiles to calculate. This only works with the native method.
# percentiles = [50, 95, 99]
## Specify the ping executable binary.
# binary = "ping"
## Arguments for ping command. When arguments is not empty, the command from
## the binary option will be used and other options (ping_interval, timeout,
## etc) will be ignored.
# arguments = ["-c", "3"]
## Use only IPv6 addresses when resolving a hostname.
# ipv6 = false
# # no configuration
Oh and I’ve assigned the INFLUX_TOKEN ev with the newly created token mentioned above through cmd. At the moment I’ve confuged telegraf as a windows service which seems to be running.
Problem
Via docker’s Logs on my influxdb container I keep getting the following error line each time telegraf does it’s thing every 10s:
ts=2021-04-19T12:53:51.723912Z lvl=info msg=Unauthorized log_id=0TbU2Hs0000 error="authorization not found"
ts=2021-04-19T12:54:01.736049Z lvl=info msg=Unauthorized log_id=0TbU2Hs0000 error="authorization not found"
ts=2021-04-19T12:54:11.742796Z lvl=info msg=Unauthorized log_id=0TbU2Hs0000 error="authorization not found"
ts=2021-04-19T12:54:21.745119Z lvl=info msg=Unauthorized log_id=0TbU2Hs0000 error="authorization not found"
ts=2021-04-19T12:54:31.759499Z lvl=info msg=Unauthorized log_id=0TbU2Hs0000 error="authorization not found"
ts=2021-04-19T12:54:41.758019Z lvl=info msg=Unauthorized log_id=0TbU2Hs0000 error="authorization not found"
ts=2021-04-19T12:54:51.765318Z lvl=info msg=Unauthorized log_id=0TbU2Hs0000 error="authorization not found"
ts=2021-04-19T12:55:01.764073Z lvl=info msg=Unauthorized log_id=0TbU2Hs0000 error="authorization not found"
ts=2021-04-19T12:55:11.769352Z lvl=info msg=Unauthorized log_id=0TbU2Hs0000 error="authorization not found"
ts=2021-04-19T12:55:21.780970Z lvl=info msg=Unauthorized log_id=0TbU2Hs0000 error="authorization not found"
ts=2021-04-19T12:55:31.790098Z lvl=info msg=Unauthorized log_id=0TbU2Hs0000 error="authorization not found"
ts=2021-04-19T12:55:41.802213Z lvl=info msg=Unauthorized log_id=0TbU2Hs0000 error="authorization not found"
ts=2021-04-19T12:55:51.807681Z lvl=info msg=Unauthorized log_id=0TbU2Hs0000 error="authorization not found"
Then, when checking back in the influx UI in the “Data Explorer” I (obviously?) see no data after selecting my custom created bucket.
I’ve tested a bunch of stuff and read through a lot of topics trying to figure this out with my lack of knowledge, but can’t seem to get any further.
Can anyone point out what I should change to get this working?
