Hello everybody,
i’m having problem with flux, when i lunch “influx -type=flux” something strange happen: look the image…
I can’t use flux and i don’t know why.
I’m using influxdb 1.7.10 on windows 10.
Thanks.
Hello everybody,
Thanks.
Hello @domdin,
Welcome! Have you enabled flux in the config yet?
Hi @domdin,
Those are ANSI color codes that are sent via terminal escape codes.
These aren’t supported by Windows cmd.exe
You are welcome to ignore them, or try the latest Windows Terminal or PowerShell.
Yes, i did. Enabled!!
