I’ve not had chance to play with flux yet but it looks like you’ve enabled flux, but the config setting is still commented out so won’t work. Remove the # from # flux-enabled = true
I can’t remember if http is enabled as a default, if you changed that one as well then you will need to remove the # from that line.
