Hi all!
Please help me
I have these variable topics
neuron/Site_1/Network_1/Device_1
neuron/Site_1/Network_1/Device_2
neuron/Site_1/Network_1/Device_n
or
neuron/Site_2/Network_1/Device_1
neuron/Site_2/Network_1/Device_2
neuron/Site_2/Network_1/Device_n
or
neuron/Site_3/Network_2/Device_n
my mqtt message is like this
“node”: “Network_1”,
“group”: “Device_1”,
“timestamp”: 1707303642843,
“timestamp”: 1707303643843,
“values”: {
“Tag1”: 134,
“Tag2”: 345,
“Tag3”: 3543
“errors”: {}
I want to filter in influxdb by Site / node / group / values .
After a lot of lost nights nothing works.
Help me please!
Hello @Catalin_Grancea,
Welcome!
What do you mean you want to filter in influxdb?
Do you mean query?
If youre using 2.x it would look something like:
from(bucket: "your_bucket")
|> range(start: -1h) // Adjust the range as needed
|> filter(fn: (r) => r["_measurement"] == "measurements")
|> filter(fn: (r) => r["Site"] == "Site_1")
|> filter(fn: (r) => r["node"] == "Network_1")
|> filter(fn: (r) => r["group"] == "Device_1")
|> yield()
I think you could do something like:
# Global Telegraf configuration settings
[agent]
interval = "10s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 10000
collection_jitter = "0s"
flush_interval = "10s"
flush_jitter = "0s"
precision = ""
# MQTT Consumer Input Plugin
[[inputs.mqtt_consumer]]
servers = ["tcp://your.mqtt.broker:1883"]
topics = [
"neuron/+/+/+"
qos = 0
connection_timeout = "30s"
persistent_session = false
client_id = ""
username = ""
password = ""
data_format = "json"
json_name_key = "measurement"
json_time_key = "timestamp"
json_time_format = "unix_ms"
tag_keys = [
"node",
"group"
# Custom processing to extract Site, Network, and Device from the topic
[[processors.regex]]
namepass = ["mqtt_consumer"]
[[processors.regex.tags]]
key = "topic"
pattern = "neuron/(.*)/(.*)/(.*)"
replacement = "${1}"
result_key = "Site"
key = "topic"
replacement = "${2}"
result_key = "node"
key = "topic"
replacement = "${3}"
result_key = "group"
# InfluxDB Output Plugin
[[outputs.influxdb_v2]]
urls = ["http://your.influxdb.server:8086"]
token = "YourInfluxDBToken"
organization = "your_org"
bucket = "your_bucket"
Although I haven’t tested it.
Hi
Thanks very much!
I did it yesterday night with json_v2. And it works very well. But I couldn’t do the topics either. I tried with what you gave me and it gives me an error:
[processors.regex] tags: Using explicit mode...
[inputs.mqtt_consumer] Connected [tcp://192.168.0.203:1883]
I separated the “node” and “group” fields based on the mqtt message. And now I want to display from topics only the “Site” filter and under it to have “Site_1, Site_2, Site_n”. The name of Site_1 is a variable, it can take any other name.
I have attached a picture of how I would like to separate the topics
Certain fields do not write my new name (see in the picture)
I want to exclude the “host” filter, how do I do that?
Thanks a lot again!
