hi still new into telegraf config, so i want to make the “_” in this topics into however i put it in mqtt
sensor/lokasi/_/value
example:
sensor/lokasi/3 meter/value
sensor/lokasi/6 meter/value
sensor/lokasi/10 meter/value
i try with this configuration it didn’t do what i wanted to do
[[inputs.mqtt_consumer]]
servers = ["mqtt://192.168.1.6:1883"]
topics = [
"sensor/lokasi/+/#",
"sensor/lokasi/+/+",
"sensor/+/+/+"
qos = 1
connection_timeout = "600s"
max_undelivered_messages = 1000
persistent_session = true
client_id = "telegraf_cf820687"
username = "Rahman"
password = "<credential>"
data_format = "value"
data_type = "float"
topic = "sensor/lokasi/+/+"
measurement = "measurement/_/_/_"
tags = "_/lokasi/_/_"
fields = "_/_/_/ppm"
i try testing it by sent payloads with mqtt explorer but the configuration only sent this topic into data base
sensor/lokasi/kedalaman/value
the rest of topics like the examples above only appeared in mqtt explorer and in the telegraf log it seems like it ignored the message. what can i do to change the config so it become examples above and in influx is like the example below?
