Help with Telegram MQTT Parser
Hello ,
i am using zigbee2mqtt and I would like to parse the data from MQTT to InfluxDB.
Till now i am using this configuration and all is working as intended , however now i want to use Device name as a tag and configure:
topic = “zigbee2mqtt/+/#”
measurement = “measurement/ _ / "
tags = "
/Device/ _”
When i added the topic parsing , Telegraf start generating errors as :
2022-10-06T12:54:25Z E! [inputs.mqtt_consumer] Error in plugin: metric parse error: expected tag at 1:33: “{"battery":77.5,"humidity":39.58,"linkquality":142,"temperature":24.41,"voltage":2900}”
It kinda try to look in the Json, instead of getting the tag from the Device name which is in the topic.
Any help will be really appreciated.
[[inputs.mqtt_consumer]]
servers = [“tcp://192.168.1.44:1883”]
topics = [
“zigbee2mqtt/BathTemp/#”,
“zigbee2mqtt/KitchenMotionSensor/#”,
“zigbee2mqtt/LightSLivingRoom/#”,
data_format = “json”
json_time_key = “”
json_string_fields = [“state”,“occupancy”]
Hello @Tihomir_Karagyozov,
Let me connect you with @Jay_Clifford our MQTT expert.
Thank you .
I figure it out :wink:
I forgot to add topic when I defined the parser, now is working with this code
topic = “zigbee2mqtt/+”
measurement = “measurement/"
tags = "
/Device”
