i try to understand the mqtt topic parsing but i’m a bit confused about this. First of all, can i found some where in telegraf a place where are some log messages created from telegraf to get a hint what the problem ist? At them moment i get a connection to the influxdb but no data are showing up.
And second, which settings are necassry to get this MQTT value in influxdb
{"ArrivalTime": "2024-07-09T08:43:14+02:00","TP": "FW_Zaehler_080","Tag": "HQ","Val": 69770.000}
The Telegraf config look like this. For the moment i try only one single Topic, but it will be a couple of more when everything works.
# ## Abonierte Topcis
topics = [
"LoRa/Klima/CO2/014",
# ## Data format
data_format = "json_v2"
I try to get some info from google but unfortunaly i don’t really now where to start
